Question about MSI Computers & Internet
I have a msi cx700 doesnt power on without ac power adapter. the screen doesnt werk
  • 2,567 Answers
Looks like a battery problem. Please refer to the following article for a detailed troubleshooting/diagnosis procedure:
http://www.fixya.com/support/r6416948-troubleshooting_laptop_power_failures
Posted on Nov 03, 2010
I need the part number for the laptop MSI CX700 LCD bracket (right)
No two PCs/Laptops are equal, so if I were to give you a part No. without knowing your PC/Laptop hardware, I'd be giving you generic information, and not the specific info you require.
My best advice is to take the unit to your nearest PC shop/repairer and they'll find this for you and give you a quotation as to cost of part and cost or repairs.
I hope I have been helpful.
Cheers,
Peter
Feb 21, 2013 | MSI CX700 LAPTOP LCD SCREEN 17.3" WXGA++...
Msi s6000 was working but cut off and will not power up
Disconnect Ac adapter, remove the battery, Plug back in Ac adapter and try to turn on. If that works shut down from menu, then replace battery and start up again.
Apr 03, 2012 | MSI S6000017US PC Notebook
MSI S6000 power jack is very loose and does not make a connection to charge the battery or run off the electricity.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 25, 2011 | MSI S6000017US Laptop
My latitude D530 laptop doesnt recognize the ac adapter anymore a screen tells me to reset the adapter, how do you do that. I been using this adapter and battery for awhile now it doesnt recognize it
The AC adapter has a small wire in the center of the connector to the system. This sensing wire, if bent or broken will cause the error you mention.
If it's still under warranty contact Dell Support. If not, you'd better buy one replacement.
Try this link: http://www.chargerbuy.com/replacement-dell-latitude-d530-ac-adapter-65watt-19-5v-3-34a.html
Mar 09, 2011 | Dell Latitude D530 Laptop AC Power Adapter...
It just wont turn on i have checked the power lead and its ok its an acer aspire 5050 laptop
Hi. I would suggest you double check the ac adapter if the powercord is properly attach to it ot also you might want to try powerdraining or powercycling your computer. To do this you must turn off your laptop then remove the battery and unplug the ac adapter then press and hold the power button for 20 seconds while the battery and ac adapter is out, after that place back the battery and plugin the ac adapter and try turning on your laptop, if this doesnt work then try power draining it again and just use the ac adapter or just plug it in without the battery then try again turning it on. If it still has the power issue then try a known good ac adapter so that you could double check that it is not an ac adapter issue or a battery issue. If all that trouble shooting step doesnt work then you could also try calling acer tech support to help you on your issue if your machine or laptop is still under warranty they would help you fix it by sending that laptop to there depot without any charge. Hope this Helps
Jun 09, 2010 | Acer Aspire 5050-3242 Notebook
It won't turn on
Hi. Try theses simple steps:
Remove the Battery
Remove the AC Adapter
Press/hold down power button for 10 seconds
Plug AC Adapter in and turn the computer on
If the system doesn't turn on still then there's a problem with your motherboard. and it might need replacement.
Jun 06, 2010 | IBM ThinkPad T40 2373 Notebook
My lcd screen on my new msi cx700 keeps flickering and going black. if i press the top corners of the screen bezel the screen returns to normal.Could this be a bad screen, backlight, inverter, something...
This may be due to the inverter board found behind your lcd panel.
Take it apart & solder the two sides of the coil found on the inverter board. This loose solder is caused by heat.
Please send me your feedback & vote to motivate us & to help us help you.
Feb 11, 2010 | MSI CX700-020US INTEL R4330 T4200 SYST2.0G...
Same here!
Here is what you can try to do, Remove the batteries, don't plug in the ac adapter. Press and hold the power button for ten (10) seconds then release it. plug in the ac adapter on the computer without the battery, try to turn it on. If it turns on just wait for it to load then shut it down again, if it doesnt still have the display, press and hold the power button for ten seconds to shut it down. Unplug the ac adapter put the battery in and then try to turn it on, if it doesnt have a display still, there might be something wrong with the video cable, you need to have someone do it for you. If it happens that it turns on and have display it means that you need to have your ac adapter checked. if it happens the it turns on and have a display without the battery only, you need to have your battery checked. Hope this helps
Sep 05, 2009 | Computers & Internet
Lenovo 3000 N200
sounds like the mother board maybe on its way out - is it under warranty?
Jul 24, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
Computers & Internet Logo
67 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
