Question about Acer Aspire M5641 PC Desktop
I want to instal xp how - Acer Aspire M5641 PC Desktop
  • Chris Hingee
    Chris Hingee Nov 03, 2010
    Have you got a Windows XP Home or Professional installation CD with the product installation code ?
  • 1,179 Answers
1.)Enter the BIOS by hitting the delete key during POST process.
2.)Navigate to the boot procedure of your PC and ensure your DVD writer is set to 1st boot device.
3.)Exit while saving changes.
4.)Insert the XP cd into your DVD drive.
5.)Now restart your PC.
6.)A screen will come up for you to press any key to install windows.
7.)Press any key.
8.)It will load some drivers.
9.)When the partition screen comes up leave it at it's highest number.
10.)You will need to format your Harddrive use Full format, NTFS.
11.)Insert your original CD key printed Microsoft Windows sticker that appears on your case.
12.)If asked to restart push enter.
13.)Under no circumstances should the you press any key again as this will start form the begining again.
14.)From here you just need to follow the instructions on screen.
Please take the time to rate my expertise, its the thumbs up on the top right on this solution.
Thanks
Posted on Nov 03, 2010
Sir, i am using windows 7 ultimate. i would like to install another one operating system (i.e) windows xp professional. now i insert the win xp professional disk into it but the install windows xp is...
boot your computer with windows XP cd. it will install winXP automatically but remember to install windows XP other than the drive where your win7 is. for examp: if your win7 is in C drive, install XP in D drive. hope you can do.
Aug 29, 2011 | Computers & Internet
Tip
How to install window XP
This procedure demonstrates how to install Windows XP Professional. The procedure to install Windows XP home edition is very similar to the professional edition. Since Windows XP Pro is more advanced operating system, it will be used to demonstrate the installation procedure.
The best way install Windows XP is to do a clean install. It is not difficult to perform a clean installation. Before you perform the installation I recommend that you check to ensure that your hardware is supported by XP. If your hardware is not on the compatibility list you can check your hardware manufactures website to download the drivers for Windows XP. Save all the necessary drivers onto floppy disks or CD before you start the installation.
click on lick ...How to install the window XP
on Jan 09, 2010 | Computers & Internet
Can i install windows-xp on my laptop which is currently working on windows-7 and use both of them.
Yes you can install windows xp in windows 7.
Windows XP Mode is a virtual PC image of Windows XP Service Pack 3 that could be run on Windows 7 Professional, Enterprise or Ultimate versions. Applications installed into Windows XP Mode could be run in Desktop Mode or Seamless Mode. In Seamless Mode, applications appear to run natively within Windows 7, but they are actually running inside the Windows XP virtual machine. Windows XP Mode might also provide additional integration that traditional Virtual PC images might not be giving. Applications installed on the Windows XP image could be exposed to the Windows 7 Start menu. Applications run in seamless mode is having automatic access to the Windows 7 known folders like Documents, Pictures, Desktop, Music, etc. Also the Cut-and-paste is enabled between native Windows 7 applications and those running in Windows XP Mode. Applications running in Windows XP Mode might also access your Windows 7 network connection and USB devices.
Nov 30, 2010 | Computers & Internet
I want to install xp by removing my pre installed vista in presario cq61-132tu. and there is no option of sata in bios so plzzzzzzzzzzz help me. i want to operate only xp means i m not want to install both...
Put XP disk in CD-ROM and reboot the computer.
Click yes to install XP. It will tell you there is a system already installed on C drive. You select to install XP on C drive. It will ask if you want to format C drive, you select full format.
XP will then install
Sep 24, 2009 | Compaq Computers & Internet
I hate Vista. I want XP.
Hai,
Yea that's true Vista sucks.....XP best!
If you want to install completely with XP then as usual procedure format the system with your Windows XP CD(C:/ drive only, with FAT32 or NTFS).
Aug 23, 2009 | Microsoft Windows XP Professional SP3 Full...
Windows xp installation problem
You might need to use the "Floppy" version of the Driver upon install (if you know what the chipsets are. Most likely it's Intel and you can slip stream the driver files into a new XP CD.
However if a partition is formated from Vista and you attempt to install XP over it without formatting it, crash is almost certain - XP and Vista have different versions of NTFS.
If you want both XP and Vista on the same machine, ALWAYS install the older one first! i.e. XP first. And create only 1 partition in XP where you intend to install on.
Then install Vista afterwards with Vista created partition.
May 23, 2009 | EliteGroup RC410L/800-M2 (V1.0)...
How to Install Windows XP
  1. Take backup of all your data like picture,document, videos, etc...
  2. Put OS Cd in and As soon as you turn on tap F12 then select CD ROM on the list
  3. Then it will give a message " Press any Key"
  4. As soon as u see the message press Enter
  5. It Setup XP OS then it takes to partition Screen.
  6. For XP  click on the link for clean installation http://gur.in/clean.htm
Hope this helps
Regards,
Prem
Feb 18, 2009 | Dell Computers & Internet
This S-Ata version for Windows 2000-xp only
To intstall xp sp3 you need to install xp sp 2 then you can go ahead fo xp sp3 installation. Otherwise, install the xp sp3 by bootable CD.
Feb 16, 2009 | Soltek SL-86SPE2 Motherboard
Not possible xp installation
How to Downgrade Vista to XP Downgrading from Windows Vista to Windows XP is almost like installing Windows XP for the first time. You should take all the normal precautions like backing up all your important files and record important passwords in a different place, preferably on a CD. When you downgrade from Windows Vista to XP, note that Windows Vista will be completely removed from your system.
(Note: There is a way to have both Vista and XP in a dual boot configuration, but that's an option for more advanced users. See Dual Booting Vista and XP for more info on that.)
Before you begin the XP installation, make sure that the necessary XP hardware drivers are available, or included on the XP disk provided by your PC vendor. If in doubt, check the vendor's website or poke around with your favorite search engine to see if others have attempted the XP install on the same hardware. You may be able to install XP without all the needed drivers, but some hardware may not work afterwards.
Also, make sure that you have a genuine Windows XP CD before you begin the downgrade. Be sure to read the section earlier in this article to see if you qualify for a low/no cost XP recovery disk from your PC vendor. If not, perhaps you have an XP disc that came with another computer. If you've upgraded an existing computer from XP to Vista, the best choice would be the XP install/recovery disc that came with that computer. One some PC's the vendor doesn't ship a CD, but the recovery CD can be created from disk images on the hard drive. If all else fails, you can always buy a copy of Windows XP on Ebay. Just be sure it's a legal, licensed copy.
Follow these steps to install Windows XP on your Vista machine:
  • Insert your Windows XP install/recovery CD and restart your computer.
  • Install Windows XP normally, providing either the product key that came with the disk, or the one you got from Microsoft customer support. If the installer warns you that another copy of Windows is already installed, don't worry. Remember, this install will wipe out your existing Vista installation.
  • Activate your copy of Windows XP when it prompts you to do so. If you run into the "already activated" problem, you can use the option to activate by phone.
  • If you own Vista Business or Vista Ultimate, explain to the rep that you want to use your Downgrade Rights to install XP Pro.
  • If you own Vista Home Basic/Premium, or you are installing XP Home Edition, don't mention ANYTHING about Vista. Just give the rep your XP product key (not the Vista key), explain that you are installing XP on a new hard drive, and tell them you need to activate.
Mar 30, 2008 | Computers & Internet
Acer Aspire M5641  PC Desktop Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
