Question about Canon LIDE20 Flatbed Scanner
Windows vista ultimate 64 bit
No driver issued from cannon for the lide 20 to date to suit my OS. Scanner is not very old and is already obsolete if I can not even use it.. Doh! If this is not fixed asap I will have to buy another and I will be sure to make sure it is not another cannon if there tech support does not get things moving! Very unhappy :-(
  • 1 more comment
  • massivewaves Jun 13, 2008
    With quad core processors pretty much being the norm these days, there is very little 32 bit processors even available on the market. AMD and Intel have jumped ship a long time ago now so one would think that Canon would respond by creating drivers to suit! This is a serious let down as every other piece of hardware I have has had no issues with giving the correct drivers to me. Ah, apart from a four year old ten dollar chinese web cam, but that I kind of expected! Canon should have there **** together on this one as they are no back yarders and have a responsibility to look after there customers. If I have to buy another scanner I will never purchase Canon again and I will be relaying this info to all I know. I have spent thousands on Canon gear in the past years and have always been a loyal customer. Once bitten, twice shy!
  • jenrob5 Aug 21, 2008
    Same problem. Rang Canon & they were as helpful as T.... on a Bull.
  • lasha999 Jan 31, 2009
    I have same problem. No driver for Vista 64.
  • Canon Master
  • 2,794 Answers
This is going to be a problem with Vista 64 since all the drivers before were 32 bit. There have been plenty of warnings out there about it.
Unless you can adapt the 32 bit driver to the hardware or wait and see if Canon will support it, thats going to be the situation.
I remember seeing the same thing when we were switching from 16 bit drivers to 32 bit drivers years ago. I don't miss those days.
Posted on Jun 13, 2008
I need a driver for lide80 canoscan scanner
What OS do you have? The drivers (supported OS versions) for the LiDe 80 are available here: http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_80#DriversAndSoftware . If you have Win7 64-bit, the Vista x64 driver doesn't work even in the compatibility mode.
If you want a work-around for the 64-bit OS, Win7 Pro and Ultimate allow you to download and install XP mode free. This takes two programs, Virtual PC and the XP mode, that you download from Microsoft and install. This will run a virtual computer under Win7 and you can install the scanner to the virtual computer. To share files with the real computer, you should store them on external media.
Alternatively for Win7x64, you can install any of the other Virtual computer programs (Parallels, VMWare, etc) with a licensed older version of Windows. Then do the same as above. Another option is a dual boot computer with the older licensed version of Windows with the scanner installed to the "machine" with the older OS. I don't see a Unix driver for this scanner so you need a valid copy of Windows.
I hope this helps.
(If you have Win7 x64, the only other options are 1) to try and get Canon to extend their drivers (since they do support Win7 32-bit) or 2) get a new scanner.)
Sep 15, 2010 | Canon CanoScan LiDE 35 Flatbed Scanner
My cannon canoscan lide 20 lide 30 driver,dose not install with windows 7
Do you have the 32-bit OS or the 64-bit OS? The Canon drivers will work in 32-bit Win7. However, Canon doesn't support these scanners in the 64-bit OS. The only way to make the scanner work in the 64-bit OS is to run either a dual boot system or a virtual computer with a supported OS. The Vista x64 bit driver doesn't work even if you use the compatibility mode.
If you have Win7 Ultimate, you can download Microsoft's Virtual PC and the XP mode for free. All other virtualization software options (Virtual PC, Parallels, VMWare) require a paid (licensed) version of the OS. Then install the scanner in the virtual computer and transfer files to external media to share it with the main computer. Dual boot systems have the same restriction of needing a valid OS.
I'm not aware of any Canon drivers for this scanner under UNIX.
I wish that I could be of more help.
Sep 02, 2010 | Computers & Internet
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Driver for canoscan lide 35 for windows 7, 64 bits
this is the support site ...and the driver I found there is for windows 7 but on 32..Cause they do not have one for 64 bits OS yu should download and try the Vista one on 64 ..cause the compatibility is usually high and it s worth give it a try ..If not the only way you will be able to use is if you reinstall the windows & on 32..You will not feel much difference but the driver's compatibilities will be easier to match
May 31, 2010 | Canon CanoScan LiDE 35 Flatbed Scanner
Windows 7 64 bit driver
No problem.
1- Go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=6624#DownloadDetailAct
2- Click on "Drivers & Downloads" tab
3- Click on "Select OS" and select Windows 7
4- Click on "lide20lide30n670un676un1240uvst7031a_xpen.exe7.0.3.1a"
5- Select Open or Run
Follow the prompts to install the WIndows 7 drivers
Thank you. Please feedback me :)
Jan 31, 2010 | Canon LIDE20 Flatbed Scanner
CanoScan LiDe 60 wont work on emachine with window 7. Error about being 32 bit.
Go to the following URL: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=11446#DownloadDetailAct
Then select your OS.The drivers and software for Win7 32 bit and Win7 64 bit different. The Win7 64 bit drivers are digitally signed; the 32 bit version doesn't need the same level of security certificates (a Microsoft issue).
I hope this helps.
Dec 18, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
I have an HP laptop OS Vista i tried to
Hi There,
there are no 64 bits drivers available on the cannon website(x64) and you cannot install it using the 32 bit vista driver
Sep 03, 2009 | Canon CanoScan 5000F Flatbed Scanner
Canon lide scanner vista 64 drivers
This is the link to the drivers and CanoScan Toolbox.
Click on the
Drivers & Downloads on this page then choose Vista(64) as your OS
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=235&modelid=6623#DownloadDetailAct
Apr 11, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Canoscan does not work on vista 64-bit
I'm not sure if this will work on the lide 20. I have an lide 35, and there are no 64 bit drivers for it. I downloaded and installed the drivers for the lide 60, told the computer to manually find the lide 60 drivers for my scanner, and installed the canoscan toolbox for vista 64 bit. Works like a champ.
Nov 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon LIDE20 Flatbed Scanner Logo
233 people viewed this question
old marine
old marine
