Question about Kitchen Appliances - Others
My Nuova simonelli panini grill lid won't stay suspended any longer...think the spring is defective. How can I replace the spring or any other suggestions on how to fix it?
SOURCE: Nuova Simonelli Premier
Could be a couple of things. You will know if the pressure is bouncing around by watching your gauges. You want to pull between 9-10 bars when pulling a shot. The programming issue could be the fact that if it is used it could have what I like to call
a touchy brain board. Those do have to replaced every so often depending on how much use the machine gets. You can reprogram whenever shots start pulling bad until you have no choice but to replace the brain board. They are cashy. To program: push the stop and pitcher button at the same time and all lights will start flashing on that head. Have your grind set, use a lined shot glass and measuure your shots according to short or long, watching the flow, crema etc. The ultimate shots pull between 25 and 28 seconds.
Hope this helps.
Posted on Feb 12, 2009
  • 10 Answers
SOURCE: nuova simonelli appia 1 ....pump will not stop pumping so tank fu
Your level probe is on the right hand side plate of the boiler, normally with a red wire leading to it.
I would take the probe out (spanner reqd, obv. with no pressure in the boiler) and clean it with wire wool.Scale often causes the probes to malfunction.
Then make sure when you refit the probe, the part of the probe in the boiler faces down.
Posted on May 08, 2009
SOURCE: Need repair service in Denver, CO
Call Maric Beverage Systems they are very knowageable & the best service company in my opinion on Nuova Simonelli as well as all the others. 719-380-1610
Posted on Sep 09, 2009
espressonist
  • 1711 Answers
SOURCE: nuova simonelli master
Your proble is that the coffee group is blocked. There many reason why you have this problem, like the group motor is damage ither the motor or a gear but you have to replace the complete unit. Their is also the posibility that something is bloking the group to complete the full motion, or something might have been bend. Their is also the posibility that the group limit switches to give wrong indication so the machine can not get any move responce. Unless you have experiance with this machines you have to ask professional help since you might damage the whole group system even that the cause is might be a very stubit one.
Posted on Feb 16, 2010
hmerchant110
  • 7191 Answers
SOURCE: Instruction manual for nuova simonelli microbar expresso machine?
You can download the user manual in PDF format from the manufacturer's support website by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on May 13, 2010
My nuova Simonelli oscar doesn't heat
This is a good little machine. its basically a commercial machine shrunk down for home and is worth repairing even if you have to take it in. go to nuova simonelli usa website and download the parts manual and check the 009500014 thermal fuse and the 09500004 highlimit thermostat and see if one is gone or tripped. check the pressure stat, check if power to elements and if there is check to make sure the elements havnt failed from being heated with no water. like i said this machine is on par with a rancilio silvia so well worth repairing.
NUOVA SIMONELLI ESPRESSO MACHINES
Apr 08, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Aurelia fuse replacement
go to nuova simonelli usa and download the parts manual and locate the fuse.
Apr 05, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Panini grill overheats
thermostat problem, need to change thermostat
Apr 03, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Nuova simonelli manual switch flashes
it means that no water is flowing on the flowmeters. need to check flowmeters if clogged
Jun 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Our Master coffee is broken but can not find the new one
I would google Nuova Simonelli, they have branches worldwide.
May 27, 2009 | Nuova Simonelli Master Espresso Machine
Nuova Simonelli Jazz Plus always says water tank is empty
The guy you bought it from passed the defect on to you.
Oct 09, 2017 | Nuova Simonelli JAZZ Espresso Machine
Assembly
Are you talking about the handle?
Fit the spring in the indentation in the handle cup (just below the rim).
Then firmly push the filter inside the spring(you may need to give it a slap with the palm of your hand).
Apr 04, 2009 | Nuova Simonelli Program VIP Coffee Maker,...
Feb 26, 2009 | Nuova Simonelli Master Espresso Machine
Kitchen Appliances - Others Logo
88 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
