Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05K3CW
HI,my freezer runs fine,but I noticed where the motor side is,should there be a fan??,I feel no air moving.didn`t try to take off cover an look.an the freezer gets alot of ice at the top sides.thanks
    President:
  • 1,218 Answers
Good day,
Unlike most refrigerators and upright freezers, they don't use a fan motor. The condenser coils are imbedded in the walls of the machine, and need no supplemental cooling.
As to the ice buildup, sounds as if the gasket isn't sealing well enough. You could try cleaning the gasket thoroughly, and check the alignment of the lid to the body.
Appliance parts houses carry a food compatible spray, which may help make the vinyl more pliable.
If that doesn't work well enough, then the only option is replacing the whole gasket.
With the model number, check with the supply house to see if the gasket is a replaceable style.
Posted on Nov 03, 2010
How often does the fan rotate? and if the the fan is the problem would that stop the fridge and freezer getting cold?
If the fan is not moving you are not going to get cold air into your refrigerator section and it will start getting warmer. I would suggest pulling the fan out and if you have a way of checking it, try to run it outside the refrigerator. Most fans will run almost constantly except when the freezer is in defrost mode. More than likely though, from what it sounds like, you will probably end up replacing that fan motor.
Dec 05, 2013 | Freezers
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Upright Freezer won't Cool
Hi - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Oct 14, 2012 | Frigidaire GLFH17F8HB Upright Freezers
My true gdm-43f freezer keeps running won
Not sure exactly what the situation is I'm going to give you a detailed overview on how the system works that way you'll be able to isolate the problem. Your machine is a single compressor unit, meaning that even though there are two seperate sides, the freezer and the refridgerator, they do not operate independantly. The sealed system, which is what cools the machine, has two parts, a high side and a low side. The high side is located under the machine and consist of a condensor, for which freon is pressurized back into a liquid and passed throug the compresoor to be released as a gas into the evaperator, the low side. This is where the freon is at a cold state. Ok, now that you have the bare basics of a sealed system, we move forward. The Evaporator is located in the freezer side, behind the freezer wall. As freon goes through the evaporator, a fan, called the evaporator fan, is located above it and circulates air throughout the freezer compartment. Also, an airway connects the freezer to the refridgerator, usually top right of freezer, or top left refridgerator on side by sides and through the freezer floor on top mount models. This means the freezer cools the refridgerator side. ****First check point**** Is the fan running in the freezer? This would cause the freezer not to cool as well but also a rise in the refrigeration side would be noticed. As freon goes throught the evaporator, which is made of aluminum, the temperature levels are well below the freezing point, so frost and ice will form on the coils. Over time, this kind of build up would form a blockage, not letting air be drawn from the bottom of the coils by the fan to circulate the cold air. To prevent this from happening the a defrost heater is installed to thaw the ice away and comes on every 6-8 hours. This is initiated by the defrost timer, or in some machines an adaptive defrost control. The heater will be located at the bottom of the evaporator because hot air rises, getting maximum effect. A third part to the defrost system, the first two being the timer and heater, is a bi-metal,or terminating thermost. Its called this because when the thermostat is cold, the metal inside it constricts making a pathway for electricity to flow through to the defrost heaters so it can get hot, and as the heat rises and the ice melts away, the terminating thermostat will warm up, and the metal will expand causing the path of electricity to be broken, turing the heaters off. This is to prevent any high temperature situation from happening, like melting plastic or even a fire. If any of these parts fail, the machine will nit defrost. ***Checkpoint two***** Do you see any ice build up on the freezer wall. This ice will be completely across the back wall. Most signs of defrost problems are noticed first by a rise in temperature on the refrigerator side first. The above can be assessed with a quick look and listen. If no frost is present and the fan is running you can rule out the above. ****Please not that ice build up on just a small section, for example, upper left or right corner only is not a defrost situation but a sealed system issue, caused from low freon or a restriction in the lines and a EPA certified technician should be called.****** The last thing you should check you'll need to pull the machine away from the wall and remove the lower panel to gain access to the compressor area. What you are checking here is to see if the condensor fan motor is running and that the coils are somewhat clean enough for air to flow across them. The fan draws air from across the compressor and through the coils helping to keep the compressor temperature down and also to evaporate the water that is drain when the machine goes into defrost. Rule of thumb is if the compressor is on the fan should be. If the fan isn't runnning the heat from the compressor will be transferred to the machine and notice first on the freezer more so than the refrigerator. ****checkpoint three**** IS the condensor fan running? Are the coils clean, and can you feel the air from the fan with your hand placed on the opposite side of the coils?
The refrigerator side is usually where your defrost timer, discussed earlier is located. Also on this side is where your temperature control, or controls , are located, These controls are what are called thermostats, and have a direct line to the compressor. This means when the temperature has reached the desired setting the thermostat will kill power to the compressor in the same manner the terminating thermostat does with the defrost heater. Some models have a temperature control thermostat for the freezer and the refrigeratot, but some only for the refrigerator. The most noticeable sign of a thermostat being bad is the food in the refrigerator side will freeze, usually on any setting or the machine won't come on at all, including the fans. Problems are usually noticed on the refrigeratot side first. The last thing to discuss is The freezer and the refrigerator both are rising in temperature, but the fans are running, etc. Normally in cases like this a humming sound followed by click is heard or sometimes just the click. The humming sound is the compressor trying to start but failing and the click is the relay breaking contact. On newer machines, especially ones that fall under the whirlpool umbrella, the compressor relay, also called the start device has failed and needs to be replaced, but also the compressor itself could be bad. Well, thats the basics. I know it's long winded but I wanted to put something that you could print out and use as reference. Good luck.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 19, 2012 | True GDM43F Commercial Freezer
I have a side by side GE unit. The bottom of the freezer compartment keeps the food frozen but the upper half of the freezer will not freeze. There is a motor or a fan running on the freezer side and frost...
Try to defrost the freezer and see if the air valve opens and closes properly if all of that works then there is a problem with the fan that moves the cold air into the refirgerator
Mar 06, 2011 | GE Freezers
My freezer does not work all of the time. I HAVE NOTICED that the freezer get very hot at the top of the unit, I have measured this with a digital therm.and temperture was reading 136 degree F. and,the...
The first thing to check is the condenser coil at the bottom of the freezer. Take the slatted front cover off at the bottom where the compressor is located. You will see the conderser coils. This looks like a radiator with aluminum fins, about 16 by 16 inches square. Be sure the coils are clean. Since the compressor is close to the floor it pulls a lot of dust into the coils. You may need to take a long stiff bristle brush to get as much dust as possible off the coils. If this is stopped up, the unit will definately overheat very quickly. While you are down there make sure the fan behind the coils is running. There are several reasons the fan might stop running. The motor can burn out, something can impede the fan blades such as paper, or sometimes rodents. If the fan isn't running the compressor will overheat and shut off. Once you check these basic things, you may then have to address the problem of dissapating the heat. The answer to your question is yes, it will shut down if it gets too hot. You need plenty of air space behind and over the unit in your situation. The air needs to flow into the front bottom section of this unit and flow freely out the back. All commercial refrigeration is designed to operate in 75 degree areas. As your room temperature increases the efficiency of the freezer will decrease. It is not uncommon to find these units in kitchens where the temperature is 85 even 90 degrees. They will continue to work, but will probably run all the time. I would think if you could get 3 to 4 inches of space at the back of the unit and the two feet above the unit with clean coils and properly running fans, you should get better results. You MUST have free flowing air to keep the unit running. The ideal situation is to have the air flow directly through from front to the back of the compressor compartment. In your case, you may have to move the freezer away from the back wall and allow the air to flow up the back of the freezer and out over the top into the room. 2 inch holes are not enough.
Sep 23, 2010 | True 23 cu. ft. / 651 liter Commercial...
Temperature Alarm
Can you look behind the food and shelves at the back wall near the bottom, if there is a frost build up on the back wall we have an issue with the defrost system, this would cause poor air flow and loss of cooling. I do not have your model number but I am assuming since it is a frost free unit it has an internal fan. If so is the fan running inside, can you feel air out the vent in the top? If not your fan motor may have gone out. The next thing to check is feel the side walls of the freezer, they should be warm. If they are not the compressor may not be running. Let me know the results of these questions and we can go from there.
May 07, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Jenn-air side by side unit runs but freezer not cold
the fan motor has gone bad and need to be replaced, you will have to remove the cover inside the freezer section aand if the little fan is not truning you will need to replace it
Oct 29, 2009 | Freezers
Fan in freezer not working
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05K3CW Logo
112 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
