Question about Brother MFC-5460CN All-In-One InkJet Printer
Paper jam, open back cover, then remove paper jam
I have tried checking for jammed paper everywhere. There is nome stuck anywhere. Can not get the machine to work at all. Still says paper jam.
  • Anonymous Mar 23, 2014
    Paper move back it misses or gets stuck at the rear rollers (ascending rollers)
    cannot find back cover
Remove the paper tray. Check that the paper length adjustment is set correctly for the paper you are using. It's the small blue dam at the center 'back' of the paper tray.
Posted on Jun 25, 2008
  • 832 Answers
Ther is some tiny little paper piece left in the machine! You will find it at the left hand side near the gear wheels ;-)
Posted on Jun 15, 2008
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere? and paper is not low????
Check the complete paper path very carefully, it only takes a small fragment of paper stuck somewhere to signal a paper jam. Also check that the paper sensors have returned to their normal positions. See that the printer has not picked up a second sheet of paper and this is somewhere in the path.
Jan 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I can't see anything in the jammed spot now what?
If you do not see any paper jammed and the machine still tells you there is a jam you should try unplugging the power cable for about 5 minutes. This will let the machine try and clear out any error messages stuck in memory.
If this does not work and you are 100% certain that there is no paper or piece of paper stuck anywhere in the printer then the sensor is broken and you will need to buy a new one.
Thanks,
Pat
Nov 08, 2010 | Office Equipment & Supplies
I have a Dell 3010 that has error msg paper jam fuser 077-104. I cannot find a paper jam anywhere in the printer. I turned it off, unplugged, checked under drum, opened all doors and checked everywhere....
you need to check the fuser, sometimes a small piece of papaer or a label stick on he fuser in order to do this you need to open the back and top cover. or take the printer to service
Aug 21, 2010 | Dell 3010cn Laser Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Hi, I have an e20 cannon copier. There was a paper jam, the paper was removed and then when I go to restart the copier it still has that paper jam icon showing. I looked everywhere in the machine and there...
Hi, I solved the problem. I had another employee look it over and there was still a teeny teeny piece of paper that was still jamming it up. So once that was removed the copier started working okay again. Thank you for taking the time to try and help me. Sould I encounter any other copier problems I'll get back to you.
Oct 12, 2009 | Canon Compatible Toner Cartridge Replace...
Says there is a paper jam but we looked everywhere and there is no paper stuck anywhere in the machine
soes it say original jam or just paper jam if the jam is in th document feeder part open the top and check the sensors where the paper goes trhough.you may have to take the toner/drum unit out to reset the jam also if there is a door on the back open and close this to reset the sensors. If there was no paper the first time check the paper tray by pulling out and then look inside where the tray sits as the poaper might be stuck there.. also check the tray in that the paper sits tight in the guides and the rollers that feed are not dirty. If turning on and off doesnt get rid of the jam there is something stuck on one of the sensors..Goood Luck A
Aug 11, 2009 | Office Equipment & Supplies
Brother MFC-5460CN All-In-One InkJet Printer Logo
1,135 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
