Question about D-Link AirPremier DWL-3200AP 802.11g/b (790069273544) Wireless Access Point
We are unable to connect the internet for the desktops using dwl 3200 ap we are having one public IP and the same needs to shared for internet access for 15 desktops(with wireless adaptor) connected by dwl 3200 ap
5 Suggested Answers
SOURCE: DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Reset, hold for 10/15 secs, do it again 3 times total. Then it works.
Posted on Feb 27, 2008
tech curly
  • 298 Answers
SOURCE: DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Posted on Aug 07, 2008
  • 44 Answers
SOURCE: DWL-2700AP reset default settings
Remove 13 screws from the perimeter of the back side of the DWL-2700AP and pull the covers apart. On the inside along the bottom adjacent from where the network cable plugs in, you will find a reset button. It is next to the white plug that leads to the antenna. You will need a flat screwdriver or something thin and sturdy to wedge between the casing and the reset button. While the AP has power, press the button and hold it in for a few seconds then release. Give it a few minutes and the factory defaults should be restored. Default IP: 192.168.0.50, Default subnet mask: 255.255.255.0
Posted on Jul 19, 2009
SOURCE: Connecting D-Link DWL 3200 AP as a wireless extender to D-Link DSL-2640T
could you able to solve.pse share
Posted on Apr 03, 2010
How can I connect to my D-Link AP 3200
Hi There,
When you connect to the AP, does it ask for a Username and Password?
Username: admin
Password: "Blank"
Are you connecting to 192.168.0.50?
Are your Computer Settings correct for that IP Connection?
You would want to set you Computer with Static IP settings:
IP: 192.168.0.2
Mask: 255.255.255.0
Gateway: 192.168.0.50
DNS: 8.8.8.8
Do hope this helps!
Oct 11, 2015 | D-Link DWL-3200AP 108Mbps Enterprise...
Helllo, Just purchase the D-link Air plus Xtreme G DWL-2100AP Wireless Access Point but I cannot access to put my username/password. I connected it directly to the ethernet from the wall but I can...
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the access point (192.168.0.50).
Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK.
Step 3 Click on the Advanced tab and then click Encryption on the left side. Select the Wireless Band (DWL-7100AP only).
Step 4 Click the radio button next to Shared Key and then click Enabled next to Encryption. Make sure your other wireless devices are set to Shared Key.
Step 5 Next to Key Type, select HEX or ASCII. You will need to use the same key on all your wireless devices.
· HEX - use 0-9 and A-F only.
· ASCII - All numbers and letters.
Step 6 Next to Key Size, select the level of encryption (64, 128, or 152-bit).
Step 7 You can enter up to 4 different keys. Select the key you want to use from the Valid Key drop-down.
Step 8 Enter your encryption key. You make this up yourself. If you selected HEX, then enter a key made up of a combination of numbers (0-9) and letters (A-F). For example - A4572BCC19 (HEX).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 29, 2011 | D-Link AirPlus Xtreme G Wireless Access...
Gateway not pinging from dwl 3200 ap . AP=192.168.4.250/24 in the same subnet, gateway=192.168.4.1 , gateway assign also on wireless adapter , wireless adapter address also in the same subnet with right...
Remove the cables from the gateway router to the switch to leave only the uplink cable or connection to your telephone socket.
Test connectivity by plugging your laptop or computer directly in to the gateway router and test web access using an Ethernet cable.
Your laptop /computer may need to be rebooted for new ip. If ok reattach the unmanaged switch a retry by attaching the Ethernet cable to one of the ports on the switch. If ok, this limits the problem to the access point.
The main problem is that you have two layer 3 devices connected together by a layer 2 switch.
The solution would be to retain the configuration on the gateway if all ok. Change the access point to a different sub net and SSID to the gateway router.
If you can shut down the broadcasting from the gateway as all WLAN will be done through the access point.
Ensure that DHCP and DNS is switched on, on the gateway router.
All computers should be configured to use the gateway router address as this will allow the gateway to provide routing across the network.
Jun 30, 2010 | D-Link Computers & Internet
TALKING ABOUT THE ACCESSING THE IP ADDRESS ON THE DWL-2000A,I DON'T THINK I UNDERSTAND THE SOLUTION TO THE CONNECTION BECOS THERE IS ONLY ONE LAN PORT ON THE AP WHICH ONE CAN CONNECT TO THE MODEM. SO IF...
To connect the AP directly to your PC you sould need a "crossed" LAN cable.
On you PC you need to set a IP Address of the same subnet of DWL-2000AP (defaul IP is 192.168.0.50) like 192.168.0.xxx
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and select "Internet Protocol (TCP/IP)", click properties, now set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Confim clicking OK OK OK...
Now you can access you devices tipyng http://192.168.0.50 on your prefered browser. Default login is "admin" as username and empty password.
Let me upate.
Sep 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
DLINK DWL-2100AP
check whether DHCP is enable on ur main AP.
Apr 21, 2009 | Computers & Internet
Wireless AP is not broadcasting
i have several of thees routers they do not asine ip adresses
conect them to a router that assignes an ip
mine are hooked up to the network via a linksys sisco rv082
and they work real good
Apr 07, 2009 | D-Link AirPremier DWL-3200AP 802.11g...
Installation problem
problem in the firewall ,ip address, proxy server, and antivirus if there all then change it disable the firewall, proxy server, any antivirus and check the ip address is give right or wrong
Feb 15, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPremier DWL-3200AP 802.11g/b (790069273544) Wireless Access Point Logo
212 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
