Question about GPS
Jrc 1000 I purchased a boat with a jrc 1000 radar. Model jma-1010 It didn't have the operators manual with it. Can you folks help me track one down?
Hi , I have a JRC 1000 with manual if it can helps ( in English and french but i ma in france. You can also use the installation manual of JRC 1500 available on internet under pdf format , very similar ( same screen and operating interface )
pcg1@orange.fr
Posted on Sep 07, 2008
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
JRC Radar Scanner when rotating is noisy inside the scanner base.
There is a seal on the antenna scanner shaft, just below the seal there are two bearings, thou the antenna are enclossed moisture still get inside and get to these bearings. Try and get a small amount of wd40 on the bearings, if not, you will soon begin to see false echoes on the screen because the motor on the scanner or antenna will begin to work harder causing a drag causing these echoes. Good luck.
Jan 17, 2011 | JRC Jma-2343 4kw Crt Radar
Need to know how to connect the 12 v dc power to the unit as I lost my power cable for radar 1000
As you look at the back of the display unit, the power plug has 7 connection posts.
Top left is pin 1 Bottom Right is pin 7
Pin 1 ..... + 12v
Pin 2 ..... - 12v
Pin 7 ..... Boat Ground
Rob
Oct 14, 2010 | JRC 1000 MKII Radar GPS Receiver
Im using a 3728 radar open array..the scanning seems to be find but there's a solid circle right at the center that is blocking the display so i can't anything near my ship..
You will need to adjust the timing on the radar antenna which is in the setup menu. You will need to refer to the installation instructions on exactly how to access the installation menu. There should be a small circle in the center of the screen, but not like you are mentioning.
Mar 01, 2010 | JRC Jma-2343 4kw Crt Radar
Hello, I need a power cable for my JRC 1000. How
Hello there,
I also need this very same power cable. Did you find one already? maybe you can tell me wich one of the 7 input connections is the + and - DC power connection so I can connect this thing myself with a home made power cable. Greetings. Stan (holland)
stanvanroermund@hotmail.com
Thanks!
Oct 03, 2009 | JRC 1000 MKII Radar GPS Receiver
Draw down is to high
found my fault not i the power cable in, but the interconnect to radar dome..approx 50mm from radar screen a break in the wire, found it just by wiggling the cable.. the set wont power up if the interconnect not connected or is faulty
Apr 07, 2009 | JRC 1000 MKII Radar GPS Receiver
Manual
Your best bet would be http://www.furunousa.com/
They have an operators/installation manual section located under Products/Manuals or just click link.
If you have a problem finding the EXACT model # manuals just give em a call and find out what manual that model is associated with.
May 06, 2008 | Furuno GP31 GPS Receiver
GPS Logo
881 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
