Question about Singer 5050 Mechanical Sewing Machine
Spool Pin For Twin Needle Stitching?
I have a pattern that requires twin needle stitching. I found the twin needles easily enough, but I also need a spool pin for the second spool of thread. I can't find it any where! I know it is just a small plastic piece, and apparently they only cost a couple dollars. Where can I find this part so I can finish this project?
I found one at for 3.99
Posted on Nov 01, 2009
  • Singer Master
  • 1,388 Answers
If you do not have access to a convenient Singer dealer, or it will take too long to deliver, try a quick workaround like.......
Wrap the bottom of a nail, drinking straw, thin stick etc with cotton wool and gently jam it into the hole where the real one will go when you finally find one..........even something perched nearby or taped on needs to be reasonably stable, but with care you can "jury rig" your own to do a quick fix.
Be sensible and make it firm, but don't force anything or damage the machine !!
I hope you can see where I suggest you are heading with this...there are also free standing thread guides available out there, but if it must be finished NOW, get inventive with what comes to hand and get a real one at leisure.
Best of....
Posted on Jun 13, 2008
I inserted the twin needle and threaded it. However, I don't know what what stitch I should use.
we have no idea here either try someplace that gives sewing classes locally
Feb 16, 2017 | Sewing Machines
I just need instructions to thread a Bernina Virtuosa 160 for pintucking
Your owner's manual should have instructions for using a twin needle.
Most machines can use a twin needle. However, some machines have two tension disks so one can separate the two threads and get equal tension. (The Bernina 930 has two tension disks, so am assuming your newer machine does also.) Look at the top of your machine where the tension mechanism resides and see if there is a right and left side. In either case, do NOT thread both threads at the same time as the threads can become twisted. When threading the machine, ALWAYS RAISE the presser foot, thread one thread completely. If threading the left side of the tension disk, also thread the left needle. Then thread the second thread, making sure to use the other side of the tension disk and needle.
Just a reminder to be careful using any zig-zag or decorative stitches since a twin needle requires a narrower stitch width to avoid broken needles.
Stitching Odyssey How to use your twin needle
How to use twin needle So Sew Easy
Bernina Instruction Manuals
Jan 13, 2017 | Bernina Sewing Machines
How do I attach a twin needle post to my Bernina 950
Hello Erina
Sounds like you purchased and wish to use a twin needle which comes as two needles on a single needle shaft, correct? That is terrific and you have a wonderful machine.
Remove the needle in the machine just the same as you have been over the past 2 years. Unscrew the needle clamp screw, pull down on the needle or part of the needle in the machine and insert the new twin needle shaft into the needle bar. Tighten the needle clamp screw and thread the needles using two sources of thread on the top.
If the existing needle post is not coming out of the needle clamp easily, use a pair of pliers to grip and pull down. Cover the sewing surface to ensure that it will not be damaged as the pliers free the needle. If the needle is firmly embeded, you may need to give the pliers a gentle tap with a small hammer.
If using a zig zag stitch make sure that the width does not exceed the twin needle limit; otherwise as the needles swing from side to side they can hit the stitch plate and brake.
Happy Stitching
Oct 23, 2014 | Sewing Machines
How i use twin needel
Although your machine does come with a second spool pin to allow two spools of thread, it does not come with a button or setting for a twin needle. You can probably put one on, but I must caution you that you can only straight stitch on it, because if you try even a narrow zigzag, its likely that one of the two needles will hit the plate and break, and they are expensive.
If you want to try it, I can tell you that you need to buy a twin needle--preferably one with the two needles close together. Put one spool in its regular pin, and the other on the extra spool pin, and thread both threads exactly the same, and at the same time. You will not be able t use a needle threader--you will have to thread them by hand.
Jun 28, 2014 | Singer 2250 Tradition
Twin needle
Install the second spool pin.
Place the two spools on the spools pins, one on each spool pin.Make sure that the spools are spinning toward each other.
Thread as for single needle.
Thread each needle from a different spool.
Caution: Make sure that the stitch width is not wide than the twin needle maximum swing. Check that the needles will not hit the throat plate as they swing from left to right and back again on stitches with width.
Happy twin needling
Jan 30, 2014 | Husqvarna Huskystar 207 Sewing Machine
Do I use a twin needle with my narrow pintucking foot on my Elna quilter's Dream 2 sewing machine?
if you want to sew pin tucks, then yes, you could use that foot providing the hole is large enough for the two needles to pass through. Twin needles come in 4mm gap and 2.2mm gap so just check that it will fit. When using a twin needle, there is a lot of heat created so it is always important so sew slowly, going too fast will cause the needles to break.
Also, you should check on the twin needle type, modern machines now using a twin which is slightly offset, the block colour is usually a dark brown/red colour. Your machine may have come with a twin needle in the needle selection so take a good look at it and see if it is an offset one, then make sure you buy replacements of the same type.
THe pin tucking foot allows you to keep rows of pintucks lined up, it will have grooves in the base that you can run the previously stitched pintuck through to keep even distances. Best on lightweight fabrics like cottons, lawns, batiste etc. You'd probably go for the narrow 2.2mm twin needle to get a nice fine tuck. I like to press each seam after stitching too to give a sharp tuck.
Oct 20, 2011 | Elna Quilter's Dream 6003Q
Skips a few stitches when using a double needle. I'm using a recently acquired old Pfaff Hobbymatic and have used a double needle before on a Singer. When I tried sewing, it will stitch but then skip a...
firstly are you using a regular twin needle on a knit fabric? this could cause skipped stitches.
is the twin needle quite old and possibly blunt?
Is the Hobbymatic a model that requires a slanted twin needle, there are two types of twin needles as the computerised machines need the offset style. You can distinguish between them by the plastic block on the needle shaft where the twin needle points are set, either red or a deep brown colour.
If none of the above apply, then it is possible that the timing sequence is slightly off so that one of the needle's thread is not getting caught during the stitching.
Timing is an adjustment that I leave to the technician to address. But if you want to have a go yourself there may be some videos on you-tube for your model and how to make this adjustment to it.
Jun 18, 2011 | PfaFF Sewing Machines
When using twin needles only one line of stitching is stitching normally, the other line is jumping stitches. I have tried rethreading & changed the twin needle. With the first twin needle the left...
now that is strange. check your thread, now take that twin needle and try this, shove it very hard up into the the needle holder. my thought is that it is not up enough. because your problem is exactly what would happen should the twin needle be sitting too low. try shoving it up higher and test again.
Aug 26, 2010 | PfaFF Quilt & Craft Pro 7530
Hemming stretch fabrics
You can use a twin needle if you want the look of top stitching (like t-shirt).
For the blind hem, you need to baste the hem and then the fold so they do not shift as the machine stitches the hem.
I like to test each of these techniques by making a sample with the same fabric and adjusting length when using the twin needle or width and length when doing the blind hem.
Twin needle does limit the stitching to a straight stitch or a very, very narrow zig-zag - this has to be hand walked to be sure neither swing hits the presser foot or needle plate before stitching.
Feb 22, 2010 | Sewing Machines
Singer 5050 Mechanical Sewing Machine Logo
106 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
