Question about Nikon D300 Body Only Digital Camera
Self timer on nikon d300
Hi, i can't seem to activate the self timer on my nikon d300 any ideas? cheers sarah.
    Sniper:
  • 53 Answers
On the top of the camera, there is a dial which says QUAL, WB and ISO. Look for button and ring just below this. It should say S, CL, CH, Lv, a clock and Mup. Press the button to release the ring and rotate it to the clock icon to activate self timer
Posted on Jul 19, 2008
    New Friend:
Thank you. That has helped me too after trying everything I know and killing time.
Posted on Feb 28, 2013
How do you work the self-timer for the Nikon N5005?
Hi there fellow Nikon user. I see that you want to know you can make the self-timer work. I suggest you click on this link: http://www.cameramanuals.org/nikon_pdf/nikon_n5005-2.pdf then go to page 44-45
Enjoy!
Mar 30, 2011 | Nikon N5005 35mm SLR Camera
Hi, I am trying to use the self timer function on my Nikon D90 but it doesn't seem to work. I have checked on many sites how to use it, but whenever I press the self timer button and turn the roll left...
The button for this is on the right, the second one from the rear and it has multiple squares on it for a symbol. Pressing and holding this button down then turning the rear dial should change the shutter release function. It cycles through single shot, multiple shots low and high speed, and then self timer. You set the actual parameters of the self-timer from the custom setting menu.
Dec 27, 2010 | Nikon D90 Digital Camera with 18-105mm...
Hi, I have a Hahnel remote control for my Nikon camera... this worked well with my D60, but I cannot make it work with my D300. Both parts are working, but not each other! have the setting to self timer......
Check to see if the D300 remote setting is turned on in the camers settings if so it is possible the two cameras work on different frequencies so a different remote will have to be used.
Aug 01, 2010 | Cameras
Price for nikon d300
D300 can be found scarcely new. It has been replaced with a newer model D300S. The D300S incorporates video and both SD and CF capability for extended uses of writing the photos. One card can be used as backup, or one can be used to write RAW files and the other JPEGs. Some slight changes were added to the menu {active D-lighting}, and the D300S also was give a slight boost to 7FPS. Used D300 on the market go for $900 - $1300 depending on its history.
Apr 02, 2010 | Nikon D3000 Digital Camera
Self timer for the nikon n55
Press the self-timer button just to the right of the LCD panel and confirm that the self-timer icon appears. Press the shutter release halfway to focus and meter. Press the shutter the rest of the way to activate.To cancel, either turn the camera off or press the self-timer button until the self-timer icon disappears.
You can get a manual at http://www.butkus.org/chinon/nikon.htm
Jul 13, 2009 | Nikon Photography
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
How to activate self timer
Just to the left of the [OK] button, there is a button with a symbol that sort of looks like a clock with one hand... that is the timer button. Press that -- you should see a timer symbol appear on your display. After you press the shutter button, the picture will be taken in about 10 seconds.
Jan 03, 2009 | Nikon Coolpix L1 Digital Camera
How do I use the self timer on my Nikon D300
Hi - You can download the manual by clicking the link underlined in blue below:
Nikon D300
See page 91:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 21, 2008 | Cameras
I cannot get the ML-L3 infrared remote to work with my D300, their is no info in the manual.Any ideas
That's because the ML-L3 doesn't work with the D300, only with the less expensive models. Nikon has several different remotes available for the D300.
http://www.nikonusa.com
Aug 10, 2008 | Nikon Cameras
Sensor Cleaner making noises?? (Nikon D300)
Yes, all D300 makes this noise when the sensor is being cleaned.
Apr 24, 2008 | Nikon D300 Body Only Digital Camera
Nikon D300 Body Only Digital Camera Logo
5,606 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
