Question about RCA WHP150C Consumer Headphones
Loss of power
When u plug in the power suply the power light comes on and then the light turns back off. where should i check first??
  • 1 more comment
  • maliburacer Jun 30, 2008
    I bought a set of these off of ebay. Same exact thing happened. I thought it might be the transormer so i tried another one. it didn't help. I took the base apart but could not find anything loose or broken. I bought another set off of ebay, same problem yet again, the only differance is that these will stay on a few minutes before it turns off.
  • Anonymous Sep 09, 2008
    Can't get the base stay turned on, seems like a false contact, but there's no aparently damage
  • DHarlowe Sep 12, 2008
    Exactly the same symptoms. The transmitter light goes on and the headphones work just fine. Then the light goes out and the sound stops. Perhaps this issue is a problem with heat dissipation in the transmitter. The unit gets too hot and the transmtter shuts down. Just a thought
I have always assumed this has to do with the level of the signal coming in.
I have had these headphones for a few years, getting them at a discount outlet for cheap, and have been quite pleased with them.
The light on the front indicates 3 things.
1) no light = not transmitting and not charging
2) green light = transmitting
3) red light = charging
When there is sufficient signal to transmit, the green light comes on.
If you are getting the signal from a Stereo, the line output may NOT be enough to keep the transmission on.
There seems to be a sensor, that figures out if htere is an incoming signal to transmit. I have toyed with the idea of locating that and disabling, so it would always transmit what is incoming, even if a low signal! But I don't have the know how.
As is, I use the headphones with my PC and generally it finds the signal strong enough to continue to transmit.
.. Thanks... Andrew
PS..The toughest thing about these haedphones, is going to be finding NiCad batteries to keep them working. If you go in the store these days, you can find lots of NiMetal Hydride, and NiCad are gone from the shelves!
Posted on Oct 23, 2008
Jvc AV-48p777 turn on goes right back off thin green light wont come on again unless i unplug it
The power suply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 09, 2010 | JVC AV48P777 Television
TV red "on" light not coming on. Cannot get power to TV
The power supply board is dead.That the board where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suply board for the replacement.
Jun 10, 2010 | Element Electronics 26 in. LCD TV
I have a compac presario, plugged and still no
usually ether pwr supply or mother board. i have seen older Compaq's having bad mother boards. check pwr light on front of pc case. if orange it is mother board, if off pwr suply.
Dec 13, 2009 | Computers & Internet
Turn on and few seconds goes off
The fan is cooling the power suply and geting power from it the power suply is going bad the relay is turning the tv off to proteckt it's self.
Nov 24, 2009 | Televison & Video
The stand by light comes on but when I press the power button nothing shows up on the tv. Opened the back of the tv and manually hit the power switch and the tv doesn't power up.
there is a short circuit in the main power suply or in the high voltage power supply; a diagnosis is needed to determine what part got electrical shock. this kind of problem is average in the service bench so i recomend to ask for an estimate if you want to keep this tv
Apr 14, 2009 | Televison & Video
Sony 52inch projection nothing happens,timer light blinks all the
check powr suply for a sony wite ceramic fuse 0.01 ohm
if open rebuild or replace power suply befor turning on the unit check the H.O.T high v transistor if shorted replace and also replace vdr610 602 and 603, depending on set flyback should be changed also due to a know internal arking problem with sony fly backs.
25% of the time its just the power suply that goes bad.
Jan 09, 2009 | Sony KP-51HW40 51" Rear Projection...
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
Need help
its a faulty power suply.try shacking it whilst its on.may be a loose conection
Jul 13, 2008 | Microsoft Xbox 360 Console
Computer won't turn on
hi
check your power cable , eathing. smps check *********** bord dont touch the cabinet.i think u have motherbord grounding or your power suply of pc has pro.
Mar 20, 2008 | Computers & Internet
RCA WHP150C Consumer Headphones Logo
306 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
