Question about RCA HD52W59 HDTV Projection Television
No analog stations on my hdtv 37 inch, have no digal box just regular cable, regular cable works on normal tv
  • RCA Master
  • 2,794 Answers
Try an antenna if you want to get analog over the air. I have a feeling that with the way the standards are changing, you will only be able to get digital channels. After February, the analog channels won't be around.
If you are using cable tv you need an HDTV box to get high def.
Posted on Jun 13, 2008
The volume
What kind of connection are you using? Are you are using a regular cable connection, HDMI, S-video, RCA for external speakers, etc.? Do you have a cable box or are you using a VCR or DVD player at the same time?
Some TVs have an option to turn off the sound when using HDMI. Check the menu on the TV to see what the audio setup indicates.
Jan 27, 2014 | Envision 37 LCD HDTV L7W698
I can't seem to get the analog channels when I do a search on my RCA lcd 37 inch? Can someone help
YOU HAVE TO CONNECT THE ANNTENA TO THE CABLE PART OF THE TV AND GO TO MENU AND SCAN SEARCH CHANNELS IT HAS TO SCAN THE CABLE SIGNAL FOR DIGITAL AND ANALOG SIGNAL IT MAY TAKE A FEW MINS YOU WILL HAVE TO DO THIS TO GET ALL THE CHANNELS
Jan 26, 2011 | RCA L37WD12 37 in. LCD HDTV
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
TV somehow switched to analog even though it is a new digital TV. How do I switch it back on the remote?
It most likely has the capability to tune analog stations in as well. To get to a digital station you should just have to punch the numbers in on the remote IE: 5-1 or 5.1
Oct 17, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
There is NO SOUND from the LC3760N 37 inches TV after I turn it on. I tried these buttons: increase volume button, decrease volume button, and the mute button. The TV was working last nigth; I don't know...
The problem was caused by a loose conexion. One of the cables that goes from the DirecTV box to the TV was loose. The problem was FIXED by pushing the cables to make sure there was a good conexion.
Jun 10, 2009 | HP LC3760N 37 in. LCD HDTV
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Can't get analog stations
Good Day, Jamievass;
Please disconnect the NEW DVD Player, does analog stations come back? What input are you using; RF, Comp, hdmi? If ok try using another input or you may need a main bord that processes the signal.
Good Luck, big IRISH.
Aug 10, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
RCA HD52W59 HDTV Projection Television Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
