Question about HP LaserJet 1320 Printer
What does it mean when both the red and green light are on at the same time?
    Genius:
  • 1,148 Answers
Check hp website they will no
Posted on Nov 03, 2010
Hi my name is Mike I have a 2002 x5 and in the dash board there was 4 little green lights on on bottom right now I got one red one and one yellow one what does it mean thx lots
Hi Mike. The lights are the service maintenance lights. When an oil service or inspection service is performed the lights should be reset to all green. Over time the lights will go from all green lights and disappear until a yellow light comes on. The yellow means the next service is due. The red means over due.
Feb 10, 2017 | 2002 BMW X5
Green alarm light continuously on. Any ideas?
Green light usually means your water filter is in great condition . the light will stay on,over time change to amber then red. Red means change filter
Jul 22, 2015 | Refrigerators
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
I have a green light and a red. what do they mean?
Red means that it has power. Green means the heating element is on. The green light will cycle on and off as the thermostat controls the temperature. Allow the iron to heat til the green light goes off before adding batter. Watch for steam coming from the iron. When the steam stops the waffle should be done. Keep track of the time that it takes to cook. Experiment with cooking time for the best results.
May 09, 2014 | Toastmaster 277 Belgian Waffle Maker
I HAVE A RED AND GREEN LED LIGHT BLINKING ALTERNATIVELY. WHAT DOES THIS MEAN? OR WHAT DOES THE LIGHTS REFER TO?
the green means that the input signal is OK the green then red is a warning that you are starting to overload things but still OK red all the time would indicates overloaded not good you will hear the distortion
Apr 08, 2011 | JBL BP300.1 PowerValve Series Car Audio...
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
What does the status light mean,it's green
When it's green that just means that you're phone has service. When it blinks red that means you have a text message, virgin alert, missed call, or sometimes a voicemail message. You can turn of the status indicator light by going to Menu > Settings > Display > Status Light and select "Off".
May 10, 2010 | LG Flare Cellular Phone
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
HP LaserJet 1320 Printer Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
