Question about Garmin GPS
My gps 4280 garmin stopped telling debt of the water, i do not have a sonar selection
3 Suggested Answers
mpapog
  • 148 Answers
SOURCE: Most recent road maps for Garmin GPS V
Here https://my.garmin.com/maps/updates.htm?in=true&ni=other&deviceType=other& you can find latest.
Posted on Feb 24, 2010
elliljoker92
  • 140 Answers
SOURCE: GPS garmin nuvi 265w It does start up after
you can update ur gps and it will work again and it wont freeze anymore
Posted on Mar 24, 2011
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Hello... Have a garmin 50s and it keeps telling me sonar shut off no transducer available??? Worked fine until this past week??? Any ideas on the problem and fix? Thanks....Scott
Yea, your transducer died. check to make sure it's plugged in, if it still is, replace it. you know if it's working by a little click when you hold the puck
Jul 30, 2014 | GPS
Sonar intermittent very good through hull transducer , sonar works sometimes then will not work rest of day ,
Check the mounting location, check the cord connections, make sure the ducer is actually clicking when it is not working, otherwise either the unit or the ducer is going bad
Jul 29, 2014 | Garmin Gpsmap 441s Dual Frequency Combo...
I have a Garmin 182c with a garmin GSD20 sounder unit ,if my transducer wire is cut or nicked would it cause the unit to unit to read " sonar turned off" ?
If you nicked it good enough yes it can. If the receiver doesn't detect the transducer, a digital message on the display will indicate this.
Mar 18, 2011 | Garmin GPS
Soon after leaving the dock the sonar goes off and sometimes reads disconnected. Checked all the wires but still no luck. Seems to go off as we speed up. Any ideas? Regards Roger
My garmin suddenly was doing the same thing. After 5 days of fristration my wife disconnected everything at the unit, as did I many times with no luck, and now it is suddenly working.
We had much rain, it is possible water is in the contacts, but just a thought with that one. My guess is just vibration, and the contacts were loose. Also, make sure your transducer is clean from algae and junk, this will impeded image transmission also.
Aug 23, 2010 | Garmin GPSMAP 172C GPS Receiver
Garmin Fishfinder 140 How to reset sonar failure
Garmin Fishfinder 140 How to reset sonar failure?
Jul 06, 2010 | Garmin Fishfinder 140
The language on my Garmin Nuvi 255 is Chinese, how do I change it to English
Turn on your GPS select Tools,then select Settings,then select Language,click on voice then scroll to the language you prefer,make sure it has TTS in brackets on the voice you select,those voices tell you the street names.Good luck.
Sep 25, 2009 | Garmin nuvi 255W GPS Receiver
Sonar not working properly, intermittent
Generally, that indicates air bubbles in the water under the transducer. If you have a transom-mount transducer, make sure the bottom surface is level or angled slightly down. If you have a thru-hull, make sure your bottom is fairly clean in that area.
Oct 20, 2008 | Garmin GPSMAP 440 Chartplotter GPS with...
GPS Logo
121 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
