Question about JVC AV-36950 TV
Model AV-36950 won't turn on
Television shut itself off this morning. Timer light was flashing. Television will not turn on with remote or using the switch. Unplugging the television for a short time only caused the timer to stop blinking.
Any help appreciated. It seems like it is common problem but have not read a response that was helful.
    Problem Solver:
  • 8 Answers
Hi there, yes this is common. I dont know how much technical expirence you have, but be very careful there are many circuits that have high voltage on them, even when off, and these voltages can be lethal, especially any thing that is connected directly to the A.C. line [such as the primary of the power supply]. most of the rest of the set is isolated from the A.C. line. so be careful. now for the tecnical part, most common is a failure of the vertical circuit, the shorted IC will cause the set not to come on in order to protect the power supply. after you replace the IC and any resistors and diodes that may have failed as a result of the bad IC, change any caps related to the vertical circuit, they will be 100, 220, or 47 mfd @ 35 volts or so. lastly check the zener diode that is connected across the output of the IC for leakage or shorts. It is also possible for a filter cap. in one of the low voltage supplies to be open [it may be noticed as it will be pregnant.]to cause a no operation condition. so good luck and think safety.
Posted on Jun 13, 2008
I have a JVC AV 32432 and the on timer light is flashing and tv won't turn on.
Flashing of timer is fault indications. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 02, 2012 | JVC AV-32432 32" TV
On timer light is flashing.and tv shuts off in about 5 seconds after turnig it on.
Hello
Timer function is in ON position and have been set to the least time I thinks. You just go to the menu and put the timer fuction of OFF.
The On/Off timer lets you program your television to turn itself on or off. You can use it as an alarm
to wake up, to help you remember important programs, or as a decoy when you're not home.
Press the MENU button
Press UP or DOWN button on the remote control hanset to ON/OFF TIMER
Make it OFF.
Switch off the TV by its front panel power button, and switch it ON again after 10 seconds.
OK.
Dec 06, 2010 | JVC AV-27D302 27" TV
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
JVC AV-36950 TV won't turn on
In this case wat u can do is try to Turn On the set without the memroy card inserted....
If still same Problem u can try replacing the batteries.......
If the set turns on without the Memory card replace the memory card....
Good Luck.....
Jan 20, 2009 | JVC AV-36950 TV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
Dec 02, 2007 | JVC AV-36950 TV
Timer continuously on.....tv won't turn on
I had a simliar problem and just left teh set plugged in overnight and the next afternoon I noticed that teh remote red LED was not on anymore and tehn when I used the remote the set turned on!
Aug 28, 2007 | Akai PTH5498 54" Rear Projection...
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
Sep 12, 2006 | Philips 32RF50S 32" TV
JVC AV-36950 TV Logo
80 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
