Question about HP G60t Notebook
My laptop heats up and the internal fan doesnt turn on. Do i need to replace the internal fan?
  • HP Master
  • 32,281 Answers
Yes, especially if the fan does not spin freely. in this case it may have a seized bearing and if this problem is not fixed the CPU will overheat and shut down. Eventually the CPU will fail.
Posted on Nov 03, 2010
    Genius:
  • HP Expert
  • 1,325 Answers
Hi
do not turn the computer on anymore -- you will damage the CPU and/or mainboard
what is the exact model of the laptop ? what is the S/N (located on back of your computer)
i can help you !!
Tip
How to stop over heating laptops or computers.
1. Fix Internal Cooling. The first and most important thing you need to do when your laptop is overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card. Over time, they build up layers of dust and dirt that slow them down and block airflow.
A laptop that severely overheats causes damage to the internal components. Before this happens, the laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your laptop.
The most common cause of laptop overheating is a non-working fan. ... Viruses, spyware, adware and other types of malware put a heavy strain on the CPU and other components of your laptop. This causes those components to heat up, often to a point where the fan simply cannot move enough air over them to cool them down.
Determine Whether Your Computer Is Overheating or Just Hot. Laptops get hot. It's what they do. However, if your laptop is shutting down, suffering from the blue screen of *****, or experiencing serious slowdowns, then you have a much bigger problem on your hands.
Heat is a computer's enemy. Computers are designed with heat dispersion and ventilation in mind so they don't overheat. If too much heat builds up, your computermay become unstable, suddenly shut down, or even suffer component damage.
IF you need more info on laptops or computers go to this link...
laptop over heating Google Search
on Oct 24, 2017 | Computers & Internet
New memory nx6110
Did you remove and replace 1 or 2 RAM modules? There are 2 modules installed. One is internal and one is external. Both MUST BE OF THE SAME DENSITY OR THE LAPTOP WILL NOT WORK. You will need a second 1GB RAM Module, then use the link below to download the service manual for your laptop. Accessing the internal RAM module is fairly easy...follow the directions and you will have not problems. You CAN remove the internal one and operate the device on the single 1GB module, but I would recommend if you do that, you put the 1GB module in the internal slot. Then later, if you wish, you can add more RAM without additional disassembly. By doing this you will at least double your RAM from the 512MB you had to !GB. You can double it again with the second RAM Module to 2GB later.
.GO Here. Find Remove/Replace procedure for Internal Memory Module.
Nov 10, 2013 | HP Compaq nx6110 PC Laptop
My asus k40in laptop cpu fan turns on only when it wants to. it doesnt help much in controlling the temperature. how can i turn it on continuosly like other laptops do.
hi my name is rui it does happen a lot i suggest that you buy a external cooling system for your loptop try it. well i got a friend thats pc is on 24hrs w/a cooling system helps alot even if the internal fan is not working.,
Jul 21, 2011 | ASUS K40IN Notebook
My nc6000 starts automatically then shuts down and fan stops afterwards... pls... help
You may want to try to plug it in a power outlet and see if you get the same outcome. If no then the battery might be causing the issue and you'll have to replace it. If yes, then there could be a problem with the laptop's internal power supply. If it turns off with the power light on, it may be a loose hardware, the RAM, Processor and/ internal cables might need reseating. If this still doesn't work, then try removing the CMOS, clean it then put it back after minute.
Jun 11, 2011 | Computers & Internet
Fan doesnt work on heat cool ok
Often the fan will cycle on and off on the heat mode. A cold air prevention mode is often built into modern Ac units whereby the indoor fan wont turn on until the internal system pressure is up to a certain point and heat is available to pump into the room. If the system cant come up to pressure or temperature then possibly the system is low on gas. Place your hand on the large pipe leaving the outdoor unit, it should be HOT when the system is on heating mode and running. If not Hot, then it is low on gas.
Feb 24, 2011 | Pace 18HPEWHEC Split System Air...
My acer 5735z is over heating and turning off. the gurantee has run out on it, and i use my laptop everyday for college work, so i need it to be sorted soon. i have a cooling stand but sometimes that...
1. It is because the cpU fan within your laptop is not exhausting the heat properly for some reason.
2. Open up the laptop case and check if the fan is working properly or not. If not working, replace it immediately with a new one or it may burn out your processor itself.
3. Clean the dust accumulated on to the casing and heat sink which is under cpu fan as this may block air circulation.
4. If everything is done, your laptop should work fine. If you are not comfortable with doing youself, then seek help from any of the computer service center.
I hope this is useful to you
Thanks
Sep 23, 2010 | Acer Aspire 5735 Notebook
How to turn on the internal fan???
fans are not somethign you can just turn on or off in a laptop. the motherboard bios controls the fan. you can access your bios at boot via the on screen key then change the fan control there. other than that, your fan will work when it is needed.
Feb 12, 2010 | Fujitsu LifeBook S6510 Notebook
The fan goes on, loudly, for no apparent reason. The laptop is not overheated. It goes on and off for a few minutes, and then stops. This will happen a few times a day, and only started recently. My...
Sony laptops have a thermostat which monitors the heat internally. When it gets too hot, the fan will turn on, when the unit cools back down, it will then turn off. There is nothing to worry about.
Jan 30, 2010 | Sony VAIO VGN-CS260J/P Laptop
Advent 7104
For laptop computers there is little you can do internally - for example, you cannot replace the cpu heatsink/fan with any other one than the same model. However I've had pretty good results by getting a nice laptop stand that has one or two large fans built into the stand. This dissipates the heat generated by the laptop much more effectively than sitting on a flat desk or other surface, and with luck, it may allow you to game on without shutting down.
Also, you can turn off some of the game effects - which requires less processing, thus less heat is generated.
Feb 28, 2008 | Computers & Internet
HP G60t Notebook Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
