Question about Coby TF-DVD1540 15 in. TV/DVD Combo
My picture has gone black on this tv, i use it as a comp monitor
    Genius:
  • 1,148 Answers
Try new vga cable
Posted on Nov 03, 2010
  • dwboyer Nov 03, 2010
    all sources are blacked out i get a flash of the picture then it goes out
Hi and sorry to have bother you......I have my computer connected to TV monitor.... Before it would show the two screen, the comp and the tv. I went to hit the number lock and i hit the Scr LK button by...
On laptops both the laptop LCD screen and the external video port can be toggled to show laptop LCD, external vodeo and bothe laptop LCD and external video.
You need to press and hold down the Fn key and one of the function keys that has the monitor symbol, repeated pressing this function key will toggle the video outputs.
I cannot advise you which function key works with your laptop as they vary between different laptop manufacturers.
Sep 09, 2011 | Logitech Cordless Desktop EX110
My monitor screen is black. The green light is on but black screen
The green light usually indicates that the monitor is getting a signal.
The lack of a picture is an indication that the monitor itself is having a problem. I would test the signal with another monitor if you can get one.
I suspect that the monitor backlight has gone bad (if so, you can see the screen very faintly if you shine a light on it).
Or, the screen circuitry has gone bad.
Jun 30, 2011 | Computers & Internet
My Sansui LCD TV scren is black but there is still sound and when u change channels, you hear it changed the channel but no picture! its all black
The backlights inverter board or the power supply section for the backlights inverter board may have gone out, you need to take it apart and troubleshoot it with proper tools.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Apr 20, 2011 | Sansui 19 in. LCD TV
Soyo DYLM1988 Comp Monitor; monitor powers on with picture for only 3 seconds, then picture goes blank (black screen), the power light stays on.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | Soyo DYLM1988 Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Sometimes the picture on this monitor used to fade out to all black when my comp was idle but blocked from going standby. and recently it just quit working. when i power up my comp, the monitor gets all...
first u have to chk whether the screen has that kind of a colour in BIOS> if it has its a monitor issue> if not it can either be the video card that u use> or else the graphics chip on ur computer motherboard>
u can still try Reseating RAm and CMOS on ur motherboard then chek if ur computer boots with display
Oct 09, 2009 | Sony SDM-HS73P 17" LCD Monitor
Samsung hdtv to compaq pc
There should be a setting within the comp. Is it connected to the comp monitor and the tv? Perhaps from the comp to the tv with the monitor from the comp as well? Well if so, you may need a certain setting within the comp. Check under (on xp) display properties, and then under the settings tab. Please rate!
Apr 28, 2009 | HP Compaq nx6110 PC Laptop
Lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Apr 09, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Dell 17" flat monitor gone black
I think it might be cracked inside because it is LCD buy a new one
Jun 16, 2008 | Dell E153FP 15" LCD Monitor
Power Source Monitor
Hi
You can get another power supply at any of the computer retail stores for $40-$50. Pls take you comp's power source to the store as they come in different sizes and not all fit your comp.
Oct 24, 2007 | Balance CM2017 17" Monitor
Coby TF-DVD1540 15 in. TV/DVD Combo Logo
70 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
