Peavey 400BH the two resistors that were fried R58 and R59, 47 Ohm Flame proofs. I replaced some of t he 2K 5W, replaced the .1 Ohm 10 Watt, (2) replaced all the .33 Ohm 10 watt, the 1K 5 watts, and the 5.6 Ohm 5 watt. When I plug in the red/red-yellow/red, it goes down to 0 volts. I have it plugged in to a 100 watt light bulb to save the fuse. the lamp glows brightly. Now, when I unplug that secondary from the 400BH, and just leave the 15 volt supply on (orange/or-wh, orange works fine. Replaced the Diodes CR16,17,18,19.eplaced the Two Zeners. all the 2K 5W resistors test good out of the circuit.
  • 4,234 Answers
Thanks for the update. I'll need to look through my records for similar problems. Stay tuned...
Dan
Posted on Jun 13, 2008
Cobra 39LX blows TR15 and R58
When you replace only burned or damage parts, you should use a good meter an check all parts around them. Many times the part destroyed is just part of problem. Its going to take a service tech to really go over it now. Caps an resistors go bad when you have parts burned. Not much one can tell you without seeing it
Jan 16, 2014 | Cobra 29 WX NW ST 40-Channels Base CB...
How do i use the effects loop on peavey xr 600b?
plug the effects out into the input of your reverb/echo unit, plug the out put of the processor into an unused channel in the mixer, do NOT turn up the effects in that channel, to hear the effects in the main use the main level, to hear effects in the monitor use the monitor level. you must turn up the the effect send in the channel you want to hear the effects on and also the effects master.
Jan 23, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
Peavey 150m power amplifier - no audio, hum
Bad caps probably..old unit, do you have a capacitor analyzer...if not you might find a Sencore LC102 to test caps with on ebay...
Jan 16, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
Peavey 400B manual
go to Peavey website, select support, select owners manuals, click on archived owners manuals, select x for xr 400 b, select from the shown list.
Aug 11, 2012 | Peavey Xr600b Mixer Amplifier "last One"...
Mitsubishi WT-46805 convergence resistor location and vlaues
5a resistors are all 120 ohm 1/2 watt use flame proof resistors.
check fuse f9a23 or f9a22
also replace knowen bad caps in this unit efecting convergence replace all 10uf @ 16v on the scan doubler module, ther are 8 off them.
make shure and check trace between Rg-8 and r705 for a open, sumtimes fulid from crt will open this up.
regards
daniel.
Jan 13, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Samsung pcl5414r power resistors and pico fuses??
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me'.
Based on your original post, only the STK ICs were replaced. Presumably 392-040, the surrounding resistors and pico fuses could very well have been affected as well. Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
RZ104 -RZ106 - 270 Ohm 1/2watt
RZ133-RZ135 - 27K Ohm 1/16 watt
RZ136 & RZ138 - 3.3K Ohm 1/8 watt
RZ146 and RZ147 - 3.9 Ohm 2 watt
RZ148 and RZ149 - 150 Ohm 2 watt
while the pico fuses would look like the image below.
Good luck and Thank you for using FixYa.
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
60" Rear Projection TV
sounds like a convergence chip problem...
here is my general post for the 51 inch you'll have to look at the link for the manual and check to see if you have the STK392-120 chips or somthing bigger in the 60"
51MP392H/17
you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Aug 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Hitachi
They have it, they just list it as a 1-4 watt resistor, just order two of the 1-4 watt resistors and they will send a order confirmation inquireing which rating you need for those two items within minutes of your order.
Jul 16, 2008 | Hitachi 57F500 57" Rear Projection...
Tv has soun but no picture
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
What you need:
chips
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with.
Edwinkraus@hotmail.com
Nov 05, 2007 | Philips Magnavox 51MP392H Rear Projection...
437 people viewed this question
 Grubhead
Grubhead
