My mom has a remote that is not working for her TV. She is paralized and depends on this. I have check the batteries and that is not it.Is there a way to purchase a new one.
    Genius:
  • 2,035 Answers
You can purchase her remote online by just mention make and model of the tv ........if cannot find just give make and model number of the tv.........................
Posted on Jun 13, 2008
I had to get a new sharp roku tv remote for my moms tv. I just got it today and it doesn't work. There were no instructions regarding syncing the new remote! Help
Unplug the roku and after a few seconds plug it in. Open the battery door on the remote and push the little button you find in there. Hold the button in for 3 seconds and let go.
Sep 01, 2017 | Sharp Televison & Video
Hisense TV, remote keeps using up my batteries, only last a week or two.
seen this battery issue reported online before with these remotes
depending on age and model of that TV
you can buy new original ones
dont buy universal types for a hisense
is it the original remote ?
what brand of batteries
lithium energizer?
info
rechargeable batteries never fully charge up
only two needed
size is AAA or AA
Oct 23, 2016 | Cars & Trucks
Tv standby
If your TV is stuck in standby mode, and does not wake up with the remote, either the remote is faulty (did you check the remote batteries?) or the TV is. Inexpensive current TVs do not have manual buttons on the TV, they depend on the remote for everything.
Jul 30, 2014 | Panasonic Televison & Video
Remote control sometimes is working, most of the time is not working, so I have to turn it on and off manually
Tries check the tv remote battery compartment for moisture and rust on the remote battery like + - connections inside of the battery compartment?Yes?Take somethings sharp or a knife scrap all the rust out.Take a rag spray some WD40 and clean the + - battery compartment connections.Change another set of a new battery.If after this the tv remote still have the same problems,than the remote itself rubbers inner layer of the rubbers knobs probally warn out and not anymore make correctly contact to the tv remote PCB board anymore or the CPU chip itself it is slowly dying and shorting out of the tv remote CPU,remote devices are heavy dependent on it CPU chips.Or try website like Remotes.com to buy the tv original remote or very closed clone compatible one.
Sep 05, 2011 | Olevia LT32HVE 32 in. LCD Television
The remote will not do anything for the tv and I also tried a universal remote and that did not work also
Remotes devices are heavily depended on it CPU chip for everything,it probally already dead.Tries clean the battery compartment like - + connections and replace it with new battery.Tv remote still don't work.Try website like Remotes.com to buy a new tv original remote.
Apr 18, 2011 | Panasonic EUR501455 Remote Control
Hi hello my mom just got her new tv but she cant manage to turn it on, i'm at my work so i cant help her personlly right now
she needs to plug it in first then put batteries in the remote and turn this unit on alas make sure Mom has not used a switched wall socket.
Nov 04, 2010 | Sanyo DP32746 32 in. LCD Television
Remote stopped.
I was able to find the MSN TV Set Up Guide Manual online. Within it was the list of codes for various brands of TVs. One of those for Toshiba TV was in bold print. I used the instructions for entering the code and used that bold printed code. The remote worked both the Toshiba TV and the MSN TV2 unit after that code was entered. Apparently the remote had lost the original code somehow.
Apr 09, 2009 | RCA MSN TV 2 Digital Media Streamer...
Remote control SENSOR not working
This could be a fault with your remote control. It will need checking by a Television Technician.
You can clean the remote control yourself if you are careful. You will need a spray can of Servisol IPA 170.
  • Carefully split the remote control unit along the seal between the top and bottom of the unit.
  • Carefully notice how you then dismantle the inner components. (I lay the components out in the order I take them out of the unit).
  • In a logical order spray, clean and dry each part.
  • When you have cleaned all the components, reassemble in their reverse order of the way you dismantled the unit.
  • Fit new batteries and test the remote control.
If this fails to solve the problem, you will have to take the remote control to a Television Technician for testing.
If the remote is found to be beyond repair, visit www.semenedis.com who may be able to supply you with a replacement remote control. I trust this information will be of help to you.
Dec 04, 2008 | Toshiba 32A60 32" TV
Mom's tv
Okay check the self diagnosis feature, Hold the input and menu buttons in at the same time on the set, hold for 5 seconds see if the set blinks 1-2 blinks pauses then blinks 1-4 blinks. If so let me know the number of blinks. If not check the following items in the power supply for being open or shorted.
R9A02 R9A22 R9A23
Check Q9A51 Q9A22 also its diodes D9A31 and D9A32
Also check the 3 fues F9Doo, F9A01 and F9A06
Also check the solder on T9A20 and the flyback . Let me know what you find.
Feb 06, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Remote not communicating with TV
ok your problem is so simple,just clean the circuit board of your remote control.unscrew the remote control,get the circuit,then use a cotton with alcohol,then scrub,that's it......
Oct 27, 2007 | Emerson EWF2704 TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
