Question about Midland 5001 40-Channels Base CB Radio
Just got my new CB radio and i can hear people when in range however when i push the talk button i do not transmit. The indicator light goes on, and the Rf meter goes up but no one responds! what is the deal?
    Genius:
  • 1,274 Answers
Hi, my name is John. Welcome to FixYa. Turn your MIC GAIN to MAX. Good luck and thanks for choosing FixYa......John
Posted on Nov 06, 2010
Cannot transmit, getting a constant tone while holding talk button and transmit light not coming on, any help?
Check the headset jack. There may be something inside causing a short. also, the CLS has an audio tone out button. Be certain you are not pressing it as you push the PTT button. The PTT is odd on this radio, it is the top BIG rubber button on top FRONT. Many customers get this confused with the tone transmit button.
Nov 13, 2015 | Motorola CLS1110 Professional 2-Way Radio...
When my wife and I travel in different cars we like to use the CB. She uses the handheld, I have a CB in my truck. When transmitting I know she is talking but it is all garbled. She hears me fine.
who is transmitting if it is someone else and you are hearing garbled it could be because they are using single side band on their A.M. CB radio .which your radio cannot detect.
https://en.wikipedia.org/wiki/Single-sideband_modulation
Oct 19, 2015 | Midland 75-785 Handheld CB Radio
Handheld Radio Shack CB radio TRC-230 I can hear people but no one can hear me
First, lets make sure that the unit does transmit. Get a power meter and see how much power it transmits. If no power is being radiated, you need to have a technician check out the unit.
If you have power then pick a less crowded time to test out if anyone can hear you. Other people with more powerful equipments can only be a problem when you are transmitting on the same channel and both of you happen to transmit at the same time all the time. Chances are remote that this is your problem. Good luck. es
Mar 23, 2013 | Radio Communications
I can only hear the others. When I talk they can't hear and my red anntenna keeps coming on when I push button to talk.
Assuming the antenna is mounted and grounded correctly,when you try to transmit/talk does your meter needle move to the right with your voice,if it doesn't make sure meter knob is set to receive/transmit or mod[modulate] does it move to right now,if not make sure the mic gain knob is turned up or if it is a power mic,is it turned up&have a fresh battery.The antenna light could mean high swr readings which you will have to adjust by tuning the antenna with the radio meter or external meter,you can search swr adjustment on your computer if unfamiliar..some antenna warning lights are factory set too sensitive but most times are telling you there is a problem.If all is set&tuned properly and you still can't get a local signal to respond, your radios transmit finals could be blown,which you'll need a qualified radio tech to determine..Good luck& 73's
Aug 13, 2011 | Cobra 29 LTD CB Radio
My cb will turn on but i cannot talk to anyone, im getting nothing. Why?
Does it Transmit?? Does meter show transmit?? Can you hear?? If its hearing an transmit gone..it could be Microphone, or speaker, or other more serious problems inside circuit. Change mics and hook up Ext Spkr. If that does not do it, then radio is gone. Buy new radio instead of repairs.
Apr 09, 2011 | Radio Communications
I have a cobra 25 ltd classic that I bought from a CB shop it was fixed to have 50 W .you can see all the changes made on it .I have it hooked up with two wips 4 ft 1000 w fire sticks and a power mike it...
either he over tuned it and burned the radio out this can happen just cause a radio transmits 50 watts dosent mean the circuity can handle it and it will burn the radio because of overload. another factor is if you are running high swrs with that kinda out put you will fry it sounds like its getting hot and radios dont work well when they get hot take it to a tech tell him what was done to the radio and what it is doing. you can test the radio by buying a watt modulation meter it will tell you excacley what the radio is putting out I doubt its transmitting 50 watts that is a single final radio unless he modified the final.good luck.
Jan 15, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
I just got my new midland CB and installed it on sunday. i can hear people however everytime i try to talk no one responds. The indicator light goes on and the rf meter goes up however i am not getting...
check the SWR. the antenna may not be tuned. Also, you may be hearing skip. If so, they are thousands of miles away, and you don't have enough power to talk to them.
Find some one close to test it.
Nov 03, 2010 | Midland 5001 40-Channels Base CB Radio
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Stops working when I try to transmit.
problem may be the button loose connection to the main board...we can fix these radios. cb shop temple, tx on yahoo search. The button is connected in so it controls both sections.
Aug 03, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
Mar 30, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Midland 5001 40-Channels Base CB Radio Logo
55 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
