Question about RCA D770 Remote Control
Code search button
I can not find tthe code search button...where is it? thanks
  • heeeelpmeeee Jun 29, 2008
    I actually have the GE universal guide plus gemstar remote, but it is identical to this RCA D770. I have also found all the manual information regarding holding down the "code search/setup" button, but on this remote this button does not exist.
    Any suggestions on how to program it?
    Thanks for any help
Try under the hood of your car.
Posted on Jun 18, 2008
I don't know how to watch netflix movies through tthe wii
In the shopping channel search for the netflix channel, it should actually be on the front page. After you have downloaded the channel you will be provided with a unique code that has to be activated online with your netflix account. You can activate four devices this way. Once it is activate you can use Netflix on your wii.
Mar 21, 2011 | Nintendo Wii Console
I have an RCA RCR312W remote and lost my manual, request the steps needed to program my JVC tv / I have the codes, just need to know the steps to take ... Thank you
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
Thank you
Jan 16, 2011 | RCA RCR311B Remote Control
Formate code of nokia 6280
The format code is :-
*#7370#
Thanks.
Aug 06, 2009 | Nokia 6280 Cellular Phone
I lost my keys to my honda fourwheeler and need to remove my ignition switch to ge tthe key code. any suggestions as to the easiest way
on must honda 4 wheelers to start it all you have to do is disconnect the key just past the key it self and hit the start button
Jul 07, 2009 | Sport & Outdoor - Others
I have the 4 didget code how do i enter it on the radio
Hi
You need to press the TP & RDS buttons at tthe same time, then enter your code by using buttons 1 to 4 on the radio, then press TT & RDS again. Good luck.
Chris
Jun 12, 2009 | 1999 Audi A6
Photon Digital Scorecard - Golf
Press player button long time, then select with right hole button time mode (12hr or 24hr).
Press player button to select hour and then press rigth hole button to select rigth hour.
Press player button to select mn and press right hole button to select rigth mn.
When tthe clock is right time, press a last time the player button.
Mar 18, 2009 | Sport & Outdoor - Others
CODE FOR TRUETECH TV
There are two useful websites that give detailed instructions on how to program your RCA universal remote, even if you do not know the codes:
1) THOMPSONTV.COM/RCARC.HTML
(Use this website's instructions if your remote has a
CODE SEARCH button)
2) WIKIHOW.COM
(Use this website's instructions if your remote does not
have a CODE SEARCH button. Once you are on the
website, type HOW TO PROGRAM AN RCA
UNIVERSAL REMOTE WITHOUT A CODE SEARCH
BUTTON into the searchbox, and start the search. Then
click on the subtitle dealing with searching without
a code search button.
Hope this info helps you out. Please take a moment to rate this solution, by using the rating system below. Thanks.
Jul 28, 2008 | Televison & Video
Head Unit problem
Go to Sony.com and search out the user manual. Most of these units have a reset button for just these types of issues. The reset button is usually behind a tiny hole that you need to insert a paper clip into. You can also try disconnecting tthe ground from the car battery and reconnecting it. That could cause the radio to reset.
Jun 26, 2007 | Sony CDX-M630 CD Player
RCA D770 Remote Control Logo
172 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
