Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Refrigerator Model #ED27DSXDBOO
The moulding around both doors is hot to the touch. Does the moulding need replacing?
  • Julio1940 Jun 13, 2008
    The solution given for my problem explains why the moulding is warmer than usual. The weather has been in the 90's recently and the fridge is working harder.
    Thanks,
    Julio1940
  • 426 Answers
No this is normal, as the fridge works harder it spreads the heat to the ouside of the fridge
Posted on Jun 13, 2008
Exterior of refrigerator between freezer and refrigerator is hot to the touch
It is normal unless there is a lot of dust below your refrigerator blocking airflow. What you feel is hot gas tubes behind the surface of the metal to help reduce moisture around the door frame and door seals that will get hotter should the fan and condenser below refrigerator have a blockage of dust blocking airflow, Sea Breeze.
Jun 17, 2013 | KitchenAid Superba Architect KSCS25INSS...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Very hot to touch between fridge and freezer on front panel
on front panel around the door where the door seal goes up against is this what is hot check the compressor fan in the back of the machine when it doesnt run or is unoperational then the sides around the door get hot you might have to replace the compressor fan
Aug 12, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The doors are scorching hot to touch on my Maytag 2454. It's always been warm to touch, but all of a sudden it is too hot to even touch. It is in the center part of both doors, along the door seal area and...
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Apr 22, 2010 | Maytag MSD2454G Side by Side Refrigerator
I bought my LG Intellowasher WD-8016C second hand and have no manual. Does it need to be washed occasionally with washing sda. There is a bit of mould around the seal. How do I clean this.
Manual suggests Exterior with household detergent. Do not use methylated spirits, diluents or similar products.
For internal, dry around the washer door and run washer through a complete cycle using just hot water... and repeat if needed.
Not sure about mould.... not in manual.
Nov 02, 2009 | LG WD-16115FD Front Load Washer
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
GC5SHEXNQ02 Whirlpool 2door ref - Panel gets hot
I am not going to say the problem is normal. Normal operation those strips are placed behind the metal and inside the walls around the door seals to prevent moisture or sweating around the doors. They are usually noticed to become hot when there is a change in the control boards operation. Some brands have the hot gas from the condenser circulating around the doors. If your model has an economy switch, switch it on. I would look for any abnormal operation of the refrigerator like compressor or condenser fan stopping or ice buildup or abnormal temperatures in the fresh food compartment. If this continues I would unplug the refrigerator and open the control panel inside the fresh food section and examine both sides of the control board for signs of heat or burn marks on both sides. May not be anything to be concerned about also because this may be the first time you noticed this. But it should not be too hot to touch. Sea Breeze
Jun 23, 2009 | Refrigerators
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
50 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
