Question about Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System
My sony mhc-rv777d is not working when i on my sony within 4or 5 sec it off automatically so i need a solution
  • 10,594 Answers
MHC-RV777D shuts off itself because of protection mode that is activated to avoid further damage due to defective amplifier output IC in unit.
You need to check/ replace output amplifier IC to solve this issue, if you are not familiar with electronics stuff repair then local repair shop will do this job for you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Nov 03, 2010
  • sreejith Sep 27, 2013
    SHAHID ,HOW MUCH IT COSTS FO THE IC
I can not able to open the dvd tray in sony music system mhc-rv777d
If your system was not used for a long time , then there are more possibilities for failure of belt . I have also faced the same problem. Better get the belts replaced in SONY Service Centres
Dec 25, 2013 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
No Audio on MHC-RV777D
its a commom fault in all the Hi fi system.its a dry fault put soldering in all components. the problem may be solved.
Nov 21, 2012 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
I just want to know that how can i connect my sony mhc rv777d to my pc
Input to the the PC or OUTPUT from it? It matters.
To use the Sony as the speakers for the PC, treat the PC as you would any other audio source. You can use the headphone out or the green speaker out or any available digital output if you have one. Just make sure you adjust your PC's sound controls to enable them and turn up the volume.
Apr 08, 2011 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
My Music system is cd not read properly kindly advice
try to clean optical lens, sometimes dust can jump reading to disk. or else we need to replace the whole assembly.
Apr 06, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Not getting high depth of bass sony MHC-RV777d
I wouldn't expect huge bass from those little speakers. Somewhere on there, there's an equiliser, where you 'll probably be able to turn the bass up and down. See if that works. If not, new speakers may help.
Jan 08, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
How to incrise the bass of sony MHC-RV777d
Is it possible that the speakers are out of phase, where one speaker is moving out, the other is moving in, resulting in zero bass?
Other than checking wires, making sure + on amp is linked to + on speaker, try changing the eq settings, or sit them next to a wall - walls help bass a lot.
Cassette Stuck in Sony Hi-Fi RV-888d
Actually when audiotape struck (Click-Click-Click), rewind and forward 2-3 times or manually rewind and forward 2-3 times with the help of pen. After you can play the cassette
I am also use the same music system (MHC – RV 888D)
Mar 21, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Aug 18, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System Logo
238 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
