Picture died, no display only sound
The TV died 18 months after purchase. I did not buy extended warranty. The technician tried swapping the motherboard but that did not fix the problem. Now the tech believes the LCD itself could be the issue. Does anyone have any advice here I heard a pop and immediately the picture died, I still get sound. I have not tried any fix I am trying to figure out what went wrong.
    Problem Solver:
  • 8 Answers
Commonly when you have sound but no imagen is caused by bad connected input cable(s) or damaged cables,check your cables(component,hdmi,or avi) and/or buy a new one,the cheaper, and check again
Posted on Feb 23, 2010
    Problem Solver:
  • 7 Answers
HI there, If the screen is blank but you have sound it is not really likely to be the motherboard. Q1 is the lamp on? Look into the air vents around the top of the panel, look for any light and heat. If there is no light but some heat, point a torch at the front of the panel, in the light can you see any movement with the TV ON!!
Posted on Jun 13, 2008
Could you tell me why the picture keeps going off but the sound stays on but when i switch the tv off then back on via the mains or the remote, the picture comes back on for a few minutes before going off...
FIRST question to be asked is where did you purchase your set? If it was Sams or Cosco. You might be able to take it back under warranty!! And get another tv. Also, did you purchase an extended warranty? Maybe check into that second. If neither of those avenues work, the most likely suspected problem area is the power supply. I hope that helps you narrow it down some or fix your problem.. Good luck. HDTV GURU JAY
Apr 21, 2011 | Hitachi Televison & Video
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
KDL-40XBR5 has vertical color lines no picture .After 50 minutes picture shows back with right side darker. TV was purchase 2008
It sounds like you might have a defective LCD panel. Your warranty for your TV is 18 months. Some of these models the warranty was mis-printed and said only 12 months.
Sep 08, 2010 | Sony KDL-40XBR5 40 in. LCD HDTV
I heard a pop sound from the back of the tv and then no picture but still had sound
You know this is pretty damn strange everyone is having this problem with this Plasma TV right around the same time... When I purchased mine it stated that it had 20,000 hours of life to it... Also, I purchased the extended warranty plan for and the company that supplied the warranty went out of business so now, I have a bad TV and was screwed out of more money buying the extended warranty
VIZIO SUCKS!!!!!!
Jul 02, 2010 | Vizio VP322 32 in. Plasma TV
MUST READ THIS I have a rca 61" hdtv purchased in 2004 with a 5 year extended warranty (thankfully) and have had nothing but problems with it. it is the worst thing i have ever bought.exactly 13 months...
All DLP TVS are lemons really.Most the Convergence ICS,they use on the board held the picture together will alway die about 1 year or 1 1/2 year all way need it replace.The bulb have life spans but never reaches alway dies before than.
Apr 01, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
TV WILL NOT TURN ON BUT VIZIO LIGHT IS ON
The Service Plan from Walmart is an "extended plan" on top of the manufacture warranty. Your Tv is still under warranty from the manufacture.
Here's a link to get the info you need to get started on a warranty claim:
http://www.vizio.com/support.aspx?id=1588
Jun 27, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical line of dead pixles on Olevia 237T LCD HDTV
Replace the screen. It is faulty and is covered by your extended warranty. Any problems, contact your Trading Standards Office.
Mar 20, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Samsung LSN4041DX/X lcd tv picture. When I turn the set on, the picture is full of pixels like snow. If I turn the set off and back on, it is better, but is getting snowier each time this happens. Any...
I'm sure your joking about it being covered by warranty..Don't think Ive heard of a TV with a 11 year 4 month warranty
Check the capacitors on the power board, I'm sure you can find several bad ones..search some youtube vids on how to do this if you don't know how
Cost to repair by a technician I'd say 100 bucks
Nov 29, 2017 | Televison & Video
Do this test and it should tell if the lcd panel is bad or not, turn the tv on and touch the screen in the center, push with your finger firmly but not to hard, if you have a backlight or light shows up around your finger then it is probably the T-con board/panel, the T-con board is attached to the lcd panel and is less expensive to replace, if you do not have any light then it's probaly the power supply
Jun 13, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
No display
Under menu, option make sure that you haven't selected audion only and that input select is on the first or second options,(not the third one). If you can't even see the menu, then your connections are probably bad. Hope this helps, Mark
Sep 09, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
229 people viewed this question
Top Televison & Video Experts
Electro Med Services...
