Question about Bruder Cat Skid Steer Loader
I have an 863 bobcat skidsteer that hydraulics stay locked and I normally need to slam the bar to get them to work. What needs to be fixed?
SOURCE: what do you have to remove to get to the fuel tank
for remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
Posted on Oct 05, 2009
  • 26 Answers
SOURCE: i have a bobcat 863 it will try to start but wont
makes a click but wont turn over check the starter aint locked up.
Posted on May 10, 2010
SOURCE: i have a bobcat 773 that when i am criving it
Hi, The computer controls aren't getting enough electricity so it shuts down the machine. Tighten all of your electrical connections coming out of the battery. If any of them are loose this will happen. Tighten them up and that should solve your problem. Otherwise might be a bad fuse. The fuse box is in the panel under the seat and you can check those. Good luck!
Posted on Jun 01, 2010
  • 223 Answers
SOURCE: I have an 863 bobcat that doesn't idle well and
There should be more than just one filter on that motor, check at the lift pump and injector pump.
Gelled fuel can be a pain, if that's the problem then warm it up (tarp and salamander for a few hours or leave it inside the shop overnight if the shop is warm), top off the fuel and give it a can of Power Service brand Diesel Kleen, then try it.
lp
Posted on Dec 30, 2010
SOURCE: I have a bobcat 863,
the fuel intake is from the top of the fuel tank, there is a tube which goes to the bottom of the tank. This tube may have deteriorated and come off or have a crack. You can lift the cab and reach down to the tank to pull the plug to check. good luck
Posted on Feb 06, 2011
My 863 bobcat brush mower loses power in heavy grass. I rebuilt the pump on brush cutter. I hooked up auger and the guger turns slow like hydraulic flow is low. what should I ck.
I would flow test the pump to be sure that there are no seals that are bad or also if any of the valves in the pump are bad. If any of the valves are bad you can test the spring pressure of that valve to make sure it is within the correct specifications in accordance with the technical manual for your specific pump.
Nov 08, 2016 | Bobcat Garden
My 873 Bobcat aux hydraulics turn the wrong way it was working fine but now turns only clock ways, what is wrong
this model has got something called bi directional valves on the remotes , meaning it can move both ways , now there can b three reasons for this to go only one way , first the simplest is , what is called a lock-out reverse setting , this forces the remotes to move only one way , (there should be a note in manual about this) the second reason is the directional control valve is defective , and last but not least if your ffeedding a hyd motor with this , the motor could be defective and its only moving one way and not with much force either (a simple sub out of an std cylinder would show this)
Aug 24, 2016 | Bobcat Garden
How do i fix my bobcat 825 skidsteers hydraulics ? the right steering leaver works fine but the left does very little to nothing.
basically there are 2 points of control
1---is the control valve for that side which may not be opening the system
2--- the drive motor for that side which may be passing excessive oil and not turning
for the lift action to be slow indicates excessive pressure leakage in that circuit
early units had lever action to the control valves where as later units use electronic controls from joysticks to operate the valves
If this is your type of machine, I would be looking at faulty electronic control mechanisms or corroded wires and contacts
Dec 15, 2015 | Bobcat Garden
I have a bobcat 863. Sometimes it will not shut off when I turn it off. Any ideas?
Bobcat 863 863H Service Repair Manuals - YouTube
? 3:17
www.youtube.com/watch?v=Hsp-NAdM4Sg
Oct 30, 2010 - Uploaded by DiyRepairManuals
Bobcat 863 863H, Service Manual, Repair Manual.
Sep 15, 2015 | Toys
How do you remove motor in 863 bobcat
Removing the motor would be my last resort. That is a bunch of work.
Be sure that you are totally sure that you can't get the hose while the engine is in.
Remember that working with hydraulics can be dangerous. Lower or support all equipment, and releive hydraulic pressure before disconnecting lines.
HINT: If the ends of the hose are accessible, disconnect them and tape a piece of cord to one end. Then ease the hose out of the restricted space. Leave the cord there, and use it to ease the replacement hose back in.
STAY SAFE!
Mar 16, 2015 | Toys
Bobcat 641 skidsteer hydraulic problems.
That's one of the first things that came to mind as I was reading through your post; that the system was air-bound. Are there bleeder valves on the system?
In any event here is a website where you can buy the service manual for your skidsteer; https://mypowermanual.com/shop/bobcat/bobcat-641-642-643-skid-steer-loader-service-manual-download-6566135-10-86/
Feb 20, 2015 | Bobcat Garden
New holland ls170 skidsteer runs but will not move and hydralics do not work
Could be very expensive to fix. Check that there is hydraulic fluid in reservoirs/pumps. Check seals on all hydraulics. Check hydraulic pump. Leaks? I'm not an expert, but I almost bought a used skidsteer for next to nothing, but consulted a local excavator-guy I know on it. He steered me away from it saying "It may only be priced at $3000, but it could cost you $10,000 to fix it.
May 27, 2012 | Toys
Hydrolic arms wont lift up or down on Bobcat skidsteer 873
CHECK ALL THE SAFTEY SWITCHES ON THE SAFTEY BAR . IF THE UNIT MOVES FORWARD AND BACKWARDS THE SWITCHES AREN'T THE PROBLEM
Aug 23, 2009 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
What do you have to remove to get to the fuel tank on 863 bobcat
Jun 25, 2009 | Bruder Cat Skid Steer Loader
Bruder Cat Skid Steer Loader Logo
150 people viewed this question
Top Bruder Toys Experts
ptpumpman
Marc Taylor
Colin Stickland
Colin Stickland
Are you a Bruder Toy Expert? Answer questions, earn points and help others
