Question about EnGenius / EOC-8610 EXT / 54Mbps / 802.11a/b/g / Dual Band / Outdoor Wireless AccessPoint
I want to reset using RS323 port , i forgot its ip adress
    Scholar:
  • 124 Answers
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Posted on Nov 03, 2010
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
Can't get windows xp home edition to recognize wireless printer, even after assigning printer TCP/IP address. Windows 7 computer prints to it, but the Windows XP computer can't even find the...
Hi!
You din't wrote what's the model of your printer, but I think we can find a solution:
1. Try to ping the IP adress you assigned to the printer. If that works, please download the latest drivers or installation software from the manufacturer of your printer (or second option use the installation disk that came with your printer). If it does not reply to ping, be sure the IP adress you assigned to the printer is in same range as the IP adresses on your network.
2. It is possible that the installation software itself manage to find the printer on the network, and that means the problem is solved
3. If not, install the printer as it is local attached (e.g USB or LPT port)
4. After installing as local printer, please go to printer proprieties, go to port, choose add a new port, choose standard tcp/ip port and write for the port the IP adress you assigned to the printer.
5. Apply changes and ...that's it.
Please let me know if it helped,
Aug 10, 2011 | Microsoft Windows XP Home Edition
I want to modify ip adresse
Use notepad to write the following:
{IP;2,192,168,001,201'}
{IP;3,000,000,000,000'}
{IP;4,255,255,255,000'}
{IS;1,09100'}
{XJ;Termine'}
and print it to your printer
These will change your
IP adress
Gateway
your submask
activate and deactivate the port with an adress at 9100
and at the end display Termin?
respectiveley
Jul 21, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Bonjour pouvez vous me dire comment installer la tec sx4 en reseau sous windows xp
Pour installer en r?seau deux solutions.
1 Installer la carte r?seaux et param?trer l'adresse ip, l'adresse passerelle et le masque de sous r?seau.
Soit sur le paneau ou en utilisant les commandes ci-dessous en modifiant les valeurs:
{IP;2,192,168,001,201'} adresse ip
{IP;3,000,000,000,000'} passerelle
{IP;4,255,255,255,000'} masque de sous r?seau
{IS;1,09100'} activation du port telnet en 9100
ou
brancher un boitier axis ou netgear sur le port parallele
Feb 15, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
MY LINKSYS WRT54G2 IS OK BUT CAN'T FIND SERVER.
The Linksys WRT54G2 is Cable/DSL router with 4 port switch. It has many features including a built-in DHCP server. By default, it's IP address is 192.168.1.1, username: blank and password: admin.
Plug in the Modem to the Linksys router's Internet / WAN port then plug your PC's to any of the 4 ports (1,2,3 & 4). The Linksys router once turned ON will automatically provide your PC with IP address starting with 192.168.1.xx (x means number from 100-149).
Make sure that known working ethernet cables are being used. Check your computer's IP adress by going to the command prompt. Start>RUN>type CMD then press Enter. Type IPCONFIG and check the IP address (e.g. 192.168.1.100). Check you PC's network adapter if you don't get an IP address from the Linksys router.
You may opt to reset the router by pressing the reset button at the back for 30 seconds if it fails to give out DHCP.
Cheers!
Angel
Jun 22, 2010 | Linksys WRT54G2 Wireless Router
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
Fixed IP adress problem
You can change it but it looks tricky, when scroll for the ip address hit go then use and up and down buttom to change it, you have to change the numbers too by using up and down buttoms after you finish, hit ok.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Nov 03, 2008 | Kyocera Mita FS 1000+N Laser Printer
I HAVE A lINKSYS nh 100R 5 PORT NETWORK HUB THAT I WAS RUNNING 2 COMPUTERS. i GOT A LAPTOP AND WHEN I TRIED TO CONNECT IT WOULD NOT CONECT. THE CABLE COMPANY SAID TO RESET THE CABLE MODEN AND IT WOULD FIX...
Since you have one computer connected, try to go to linksys website. I think it is a problem with your IP adresses. If you connected your laptop and it is using the IP adress of one of the two computers, and you turn on one of your desktop, Maybe, there is one IP adress reserved and there is a conflict.
Only an hypothese...
May 21, 2008 | Computers & Internet
Default IP Adress of the modem Hughes HN7000S
The Hughes addresses are 66.82.4.8 and 66.82.4.12.
Mar 06, 2008 | Computers & Internet
Help on Port Forwardsing?
Goto your ip adress (Type it in adress bar) Your ip adress is located from www.ip-adress.com type it in, A pop up should come up "ACCOUNT" And "PASSWORD" the info should be
Account: admin
Password: admin
Or
Account: admin
Password: password
Or
Account: admin
Password: (leave blank)
then, goto "Applications and gaming" click Port Range Forwarding
Should pop up, goto Application space, name it anything (ex. echolink) From 5198 to 5199 Then select Both and for the last part you have to find it from
Start> Run> Type "Command" Then hit enter
Should pop up, just hit "Enter" and alot of stuff should come up.
Like this:
Where it says IP Address... 192.168.1.2 (Will be different for you)
That is where you put it on the last blank from your portforwarding!!
Hope I helped
Dec 01, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
EnGenius / EOC-8610 EXT / 54Mbps / 802.11a/b/g / Dual Band / Outdoor Wireless AccessPoint Logo
854 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
gggg
Tech support
Tech support
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
