Question about Sony KP-48S35 48" Rear Projection Television
Sony kp-48s35 projection
I got your answer today about my sony no power , you told me to check blue high voltage capacitor beside the Horizontal output there are number on blue ceramic capacitor was 2kv you are right I found there 3 of them right behind the Hori out put but I wondered how to test that kind of ceramic high voltage capacitor . i used the multi tester but seem none of them work with its . Please help me again I almost found the problem , Thank you Huot Fujita
  • Sony Master
  • 5,138 Answers
STKs can also shut set off BIG black ics,also check pico fuses.
Posted on Jun 13, 2008
Sony kp-51ws500 will not come on
Next to FBT flyback transfomer near the Hori output transistor is a high voltage capacitor 2k v check it it feeds to the output transistor and if it is bad high voltage will not come up.
Oct 15, 2011 | Sony KP-51WS500 51" Rear Projection...
When i turn the tv on the sound is there but no picture and the stand by/timer light is flashing
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Jun 29, 2011 | Sony KP-48S35 48" Rear Projection...
I have a sony rear projection tv that went on then off rite a way the red lite blinked 7 times i took the front panel off and adjusted the 6 color tuners and the tv stays on but there is a blue 3d look ...
7 blinks means High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 08, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony KP-57WS500 57 in. Rear Projection tv When I press the power button there is no picture but the "timer / Standby" light flashes. Sometimes when pressing the power buttonthe light flashes and I hear...
CK your hori output Transitor and behind it is a blue high voltage capacitor 2k sometimes they will have small burt hole on them ,If it is OK then Replace your STK ICs example STK392-110 Mats has them 1-800-628-1118
Feb 15, 2010 | Sony KP-57WS500 57" Rear Projection...
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony TV Projection KP-48s35
check blue high voltage capacitor next to hori out put 2k, also check STKs they can shut set down .and check all pico fuses.
Jun 12, 2008 | Televison & Video
Sony kp-57ws510
test your power supply output voltages, make sure the step down transformers are not leaking high voltage into the dc circuits. always start at the basics then work your way up or out. the most common problem for these late model tv's is power supply they just dont use quality parts anymore. in older tv's you could hear the high voltage arcs, snap today its rare for that to happen. I have a 32 inch LCD here now that actually blew a 1500 pico farad capacitor with no noise. that amazes me thats a pretty good sized capacitor, and they usually make some noise when they blow the top right off of them.
Nov 01, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp 48s35 front screen broken
http://www.partstore.com/Part/Sony/Sony/KP48S35/Sony/Sony/408470101/New.aspx
this is the link for the fresnel screen but i myself am trying to find the lenticular screen but so far no luck
Oct 15, 2007 | Sony KP-48S35 48" Rear Projection...
Sony KP-48S35 48/Broken Screen
The fresnel screen and the lenticular screen. The fresnel is part # 405845511 and is about $160 new. The lenticular is # 405845411 and is about $330.
Milford CT Real Estate
Oct 12, 2007 | Sony KP-48S35 48" Rear Projection...
Kp 48s35
This is not for the protective screen this part # is for the fresnel screen part # 405845511
Try: http://parts.com
Oct 11, 2007 | Sony KP-48S35 48" Rear Projection...
Televison & Video Logo
100 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
