Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 2
My Whirlpool Fills and washes ok but It wont drain so it doesnt rinse well at all and the tub is always filled with water after the cycle is done, I suspect that the drain hose is plugged because I hear the water rushing through the jets during the wash cycle
  • 1 more comment
  • Daniel Powell Sep 26, 2008
    whirlpool quiet partner 2 won't drain how do i get to the drain to unclog it.
    whirlpool quite partner 2 won't drain.How do i find the drain to unclog it?
  • jilly24 Nov 05, 2008
    My dishwasher is not draining, just leaves gross water in the bottom. I want to fix myself, but need a parts diagram so I know where the parts are that you are referring to.
    Thank you! I have a Whirlpool Quiet Partner III.
  • 833 Answers
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Posted on Jun 17, 2008
I have a whirlpool quiet partner 2. It won't fill with water. I have tried the trick to push heated dry/Sami over and over, but won't fill!! Help please!
Check for a solinoid valve under the machine. This shifts the pump from fill/wash to drain. Sometimes the slug in the coil gets stuck or rusted. Also, a float switch tells the water solinoid to open.
Dec 31, 2014 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Won't full cycle.
Ok. Mine has started working again somewhat. I ran a rinse cycle and the pump motor started working again. I then drained it, and started a regular cycle and it's working again for now. The motor still does not sound right though.
Mar 21, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
2,478 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
