Question about RCA F36673ET 36" TV
Set video on older 36" rca colour tv Model # f3667et
While adjusting video on tv I lost picture and unable to return tv to channel 3. No manuel.
Take hammer and give it the good ole smasharoni as hard as u can
Posted on Jul 30, 2008
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Rca proscan tv 36
PiP shouldn't matter when regarding attaching your computer to your television.
If you have the appropriate cables and ports, such as an HDMI, then you should be able to connect the two together.
I am currently using a television as my main monitor. All I had to do was connect the HDMI cable to each and select the correct input on my TV.
If you do not have an HDMI port on your computer, there should be adapters available.
At the end of the day, the only difference between a television and a monitor is that a television has tuners in it.
Sep 11, 2013 | RCA Televison & Video
Sony Trinitron XBR 36 in (TV control on Top Middle of set) (set-up / tv/video / vol / channel / power) when set is powered on the standby/stereo light Continuous blinks red once a second, no pausing -...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is exactly as you have described .....after few seconds picture comes slowly & immediately (after few seconds). it gets off only red light blinks............ .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore ..since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally .....GUARANTEE....... vishnuswamy_4.jpg
Jul 24, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
The colour has suddenly developed a green tint to the picture which I am unable to adjust The model is LE37R87BD
A green tint to a tv means it's lost its red channel (may additionally be blue channel). Check that your video cables are connected fully. If that's not the culprit, and changing tv settings doesn't work, you'll need to take it to a repair shop; so they can repair the "red circuits:" Note: there aren't any "red circuits" per 'se, but there are circuits that tell the various computer chips - in the tv - how to handle the image. By "red circuits" I'm referring to these.
Sep 05, 2010 | Televison & Video
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Rca model f36649 s-video hookup to laptop computer When I hookup s--video cable to tv & HP Pavillion dv9000. I get nothing on tv? I have tried putting tv on channel 3.
Depending on how many hook ups you have on your tv it may have a factory designated channel. Example: Video 1, Game, etc. I know my TV has several different video channels. It's more a matter of trial and error until you find the vidoe channel for your oulet. Input channels are usually found before channel 1. Or look on your remote and see if it has a button to switch the channel to your input channel. Good Luck.
May 27, 2010 | RCA F36649 36" TV
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
New tv won't set up channels
We are returning the tv to RCA and getting our money back.
Apr 18, 2008 | RCA 24V510T 24" TV
Help
Not a home repair take it to a repair store.
May 24, 2007 | Apex Digital PF3230 32" TV
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Televison & Video Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
