Question about Olympus VP-1 Projector Lamp
Olympus VP-1 proj not functioning. fan problem
HI
when i press power on the projector, it starts then stop. status light blinks red every .5 sec and power light becomes orange, which according to the manual means that the fan does not function.
i know olympus has stopped selling projectors . is there a solutin or a company thatcan repair it ?
thanks
3 Suggested Answers
SOURCE: Power on
I have same problem, Im gonna to try put a regular charger,then wi will see
Posted on Jun 27, 2008
pmacca_1987
  • 10 Answers
SOURCE: broken foot on Olympus vp-1 projector
So is the problem that the projector is now uneven and won't stand as you want?
I have a projector myself and often use other items underneath one of the sides to help me to line it up. I use poker chips believe it or not.
but as a more permanent solution I would try and remove the broken foot, place a tight fitting rawl plug in the hole left and screw a screw into the hole slowly until it fits to the size you want.
I know this is a very DIY solution but it's what I would do.
Posted on Dec 14, 2011
Testimonial: "Thanks for your time. That's a start..."
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Oct 28, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Apr 01, 2008 | NEC VT47 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
44 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
