Question about Acer Aspire L310 (ASL310UD631A) PC Desktop
No input signal
My pc was frozened, so i had shut it down and restart again. But then, message shown "NO INPUT SIGNAL". I had exchange with another monitor but still the same which NO INPUT SIGNAL. After that, I had tried my first monitor again, it's no problem, i can use it. And my question is, I dont know what was happend with my Acer Aspire L310, can you help?
    Scholar:
  • 94 Answers
Hi, there is a posibility that the issue is caused by your system unit. NO INPUT SIGNAL occurs when system unit fails to start properly. One possible reason is the power good signal was not sent back by power supply to mother board. You can check for any shorts or grounded device in your system unit. If you can reseat all the cables (power cable, IDE cable), expansion cards, memory cards even microprocessor that will be good. Another thing you can try is to power cycle your computer. If you are not confident enough to do those stuff you can call your computer vendor and ask for assistance.
Tirzo
Posted on Jun 13, 2008
How do I get out of no input signal
Hello
The video signal is not getting into your display.
Check the connections on both sides of your cable (display side and display card side). If that didn't help, switch off your PC, make sure youre display card is in its correct place (try taking it out and putting it back again). Switch on your PC and check again. If the problem continues, try replacing your display card.
Aug 11, 2014 | Sony VAIO Computers & Internet
Cannot change channel on my Dynex DX-L26-10a TV
Try checking the signal strength then run the scan again.
Checking the DTV signal strength
You can check the DTV signal strength to determine if you need to adjust your antenna or digital cable input. The higher the signal strength, the less likely you are to experience picture degradation.To check the DTV signal strength:
1.Press MENU. The on-screen menu opens.
2.Press < or > to highlight Channel, then press v. The Channel menu opens. The DTV signal strength is shown at the bottom of the menu.
3.Press EXIT to close the menu.
Oct 26, 2012 | Dell Vostro 200 PC Desktop
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Lost signal
Have you tried to push the tv input button? Sometimes when a button is buy accident it changes the input on the tv. Hope this works, let me know.
Good luck, Toni
Nov 29, 2011 | Televison & Video
Valid input signal not detected
1 unplug Dazzle from USB. turn off pc, restart with out dazzle plugged in. shut down PC, restart then plug dazzle in after PC has restarted fully. if that don't work then go to step 2. ( sometimes using a different USB port works too)
2. uninstall it and reinstall it should work fine. i had the same problem and had to many things in the USB ports at the same time.
Dec 29, 2010 | Pinnacle Dazzle DVD Recorder
No input signal on monitor after changing resolution
While booting press F8 , Go to safe mode and change the screen resolution and reboot the system.
Hope this helps
Siju.D
Nov 12, 2009 | Compaq Evo D500 PC Desktop
Screen shuts off. Power lite blinks. Aquos 42"
Hope you have the correct resolution selected:
HD View Modes: When viewing an HD program you can select the following 4 viewing modes.
  • Stretch: suitable for viewing 1.78:1 DVDs. When viewing 1.85:1 DVDs, this mode will show thin black bands at top and bottom of the screen.
  • Dot by Dot (1080i/p only): detects the resolution of the signal and displays an image with the same number of pixels on the screen. When a 720p signal is being input, the image will be delivered in full screen.
  • Smart Stretch: suitable for stretching 4:3 programs to fill the screen.
  • Zoom: suitable for viewing wide-screen 2.35:1 aspect-ratio programs in full screen.
PC View Modes: You can connect the TV to your PC through the HDMI inputs to use the TV as a monitor. The following view modes are available in PC mode.
  • 4:3 Input Signal: You can select between Normal, Zoom, Stretch, or Dot by Dot.
  • 16:9 Input Signal: You can select between Stretch or Dot by Dot.
Also verify if you have set auto timer to 30 mins or so thats why the TV shuts down after a particular time.
Thanks
May 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Acer Aspire  L310 (ASL310UD631A) PC Desktop Logo
256 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
