Question about Denon AVR-1508 Receiver
Front panel is locked and don't know how to unlock it.
    New Friend:
1) turn off the main power button (not the big LED stanby button)
2) press and hold "input mode" and "speakers" button simultaneously
3) press and hold the main power button for seconds, until display flashes.
4) release all those buttons. The AVR is already reset to factory mode.
Posted on Mar 28, 2016
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
I locked my front panel by accident and have no remote for my rca 20F514TD..how do I unlock?
Hello
To open front panel control function you must have its Origitnal Remote control. If you have lost it, try to borrow it from your friends or relatives; who owns the same model of TV as you have; just to unlock the front panel lock.
[1] From the PARENTAL CONTROL menu, press the up or down arrow to highlight
Lock Fr. Panel.
[2] Press the right or left arrow to turn on (box has check mark) or off (box doesn't
have check mark) front panel lock.
OK.
Jun 02, 2011 | RCA Televison & Video
My dryer will not come on. The time and lighting is on and then the control lock light is on.
Check to make sure you don't have the control panel inadvertently locked. If you are referring to a Whirlpool Duet, Kenmore Elite, or Maytag Epic series washer or dryer, the control lock is a built-in safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
The following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more significant problem other than a simple operator control button issue (such as an operator console problem or main control board issue).
NOTE: Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot if you cannot get the control panel to unlock.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
May 05, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Control panel locked,how to unlock
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue).
Please post back if you still need assistance. I hope this helps you.
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My control is locked. How do I unlock the controls?
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series FRONT LOADER, the following link explains how to lock/unlock this feature:
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope this corrects the problem for you.
Mar 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Forgot parental code and front panel is blocked how can I unlock?
Enter in either all zero's or all nine's. This is usually the lock reset code
Jul 10, 2009 | RCA 27R410T 27" TV
Front panel locked and remote don't work
To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Mar 22, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Unlock my tv
i have problem on my tv i dont know how unlock
Nov 11, 2007 | RCA 32F531T 32" TV
The front controls are locked
Hi, go into the menu via remote control and select special in the options. select child lock and untick it if it has a tick next to it.
This should re-enable the front control panel.
Hope it helps.
Aug 16, 2007 | LG RU-52SZ51D 52" Rear Projection...
Denon AVR-1508 Receiver Logo
262 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
