Question about Refrigerators
Refrigerator I changed the gasket around my refrigerator door but now I can't seem to be able to keep it shut on it's own. It is a Whirlpool probably from around 1993 I think. It was here when we bought the house 7 years ago. The strip on the bottom was all rotten so I got the part number and got one that is suppose to be the same type. It is different and there is magnetic in the thing but, the magnet part doesn't seem strong enough to keep the door shut or I just can't seem to get the door leveled properly. It stays open about an inch or two. I was trying to save money by fixing it myself, but my husband is telling me to call an expert to come over to fix it. I don't want to put any more money into it. I was trying to save us from buying a new one. Any help would be greatly appreciated.
  • lookenott Jun 20, 2008
    After paying $68.00 more out for a service call,(Gasket was
    $60.00,previously bought) I now have a cold refrigerator. the service man used a heat gun and ran it all over the outside of the gasket and stuck inside the vent hole from the freezer while the fridge door was shut. This brought back the memory and it actually sealed around the door frame. If I knew that was what I needed to do, I would have. Everyone mentions kinks. I really didn't have kinks in the gasket. I used a hairdryer and removed the one that I had. I didn't realize I needed to really warm up the gasket so that it was more plyable and soft. It would have taken hours with the hair dryer, but I wasted hours trying to adjust the door hinges. Oh, well, I am an expert now. If anyone needs their gasket changed, let me know. LOL
    Thanks for the free advise.
    Barb Lookenott
    Scholar:
  • 110 Answers
Use a hair dryer to heat the gasket up and gently pull all the bends and wrinkles outs. this takes a tremindous amount of patients even with us techs, so work slowly. once you have that done and the gasket shift to form the door seal put a light coat of vasaline all the way aroung the gasket then push the door shut making sure you gasket is touching the door seal all the way around it mat take going over it again with the hair dryer with the door closed to get it to form correctly, once formed don't open the door for a min. of 4 to 8hrs if it can be avoided and after that make sure you close the door and it seals for the next week to 2 weeks which is about the time it take for it to cure properly
Posted on Jun 13, 2008
Whirlpool regrigerator door auto locks
As far as I'm aware, refrigerator doors don't have auto locks on them. What you're describing sounds like the door has a fantastic seal from a temperature change between the inside of the fridge and the room around it. When there is a drastic change, (usually warm) the refrigerator seal will seem to stick. This will wear off over time, or when the temperature changes.
Jul 28, 2013 | Whirlpool ED5VHGXM Side by Side...
I have to change my door gasket.......the service engineer is demanding rs 1800 and 2-3 days to replace that.......what should i do?
NO WAY!!!! DONT GET HIM TO DO IT!!!
A door gasket costs around $50.00 and takes me around an hour or so to change. Go to another service technician.
koolman77 (refrigeration technician)
Feb 07, 2011 | Whirlpool Refrigerators
Water is leaking in the fridge; mostly probably coming from the freezer
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls
Good luck in solving the problem.....
Aug 15, 2010 | Frigidaire FRT21P6BS Top Freezer...
Leak in the drainage pan under frige
1. Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
2. Step 2 Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets
3. Step 3 If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Check out this link, its a video shows you how to fix a leaking fridge.
Apr 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from freezer
Apr 21, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water at the bottom of frig inside under crisper draws.checked door gasket it is fine cant see where water is comming from . any ideas
Apr 12, 2010 | Whirlpool ET1FTKXK Top Freezer...
Inside wall warm
Possibly the Mullion heater which keeps the door gasket from freezeing when the door is shut and humidity is high.
Oct 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Delfield Refrigerator/Freezer Condensation forming outside door seals
I would expect at the very least a heater circuit around the freezer door. Some of the commercial units also have sprung doors to keep the doors firmly shut which you could check by opening the doors. Door heater circuits are normally very reliable and it would be worth checking the voltage is getting to them, they are also a pain to change out. Hope this helps.
Aug 07, 2007 | Delfield 032-F2FH ColdPro Solid Door Reach...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
