Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
The front screen on my D52GW12 broke, can it be replaced ?
    Genius:
  • 1,030 Answers
Yes most definatly. generally there are 3 screeens on the front the protective plexi-type cover the fresnal and the lenticular. the plexi screen is known as the supersheild. is the screen cracked all the way through? the screen is held on by a number of torx 20 screen from the rear. The cost of the screens range from 80 to 250 the last one i got was from union electronics. if you can get them
Posted on Nov 03, 2010
    Genius:
  • 1,148 Answers
Yes it can,,check internet,,,,ebay and tv repair shops ,,may can find one used cheap
    Sergeant:
    Champion:
  • 271 Answers
It can be replaced if you can find it the screen. It is not that hard, you just have to be careful.
Nour Sabre
Best of luck
My 52 " GE Projection
Tv needs to be realined by adjusting the Screen Drive Controls to Tubes.
Located behind the Front bottom Panel on front of Tv.
Focus/Screen Control Block 3 on top for focus and 3 under them for screendives to each Tube R/G/B.
Jul 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 TV TURNED ON WORKED GOOD FOR 3 MIN THEN SHUT OFF . WENT TO TURN IT ON AGAIN AND GREEN POWER LIGHT BLINKED AND HERD A POP OR CRACK NOISE ..NOW DONT TURN ON . SEE 1 OF THE TUBES FLASH IN FRONT 1...
The CRT on the left will need to be replaced. You can test it by removing the CRT drive board from the bottom of that tube and leaving it suspended without unplugging any wires. try plugging it back in and pressing power. If it powers up with that drive board hanging off the bottom of that tube then you know thats the issue and the CRT ( tube) will need replacement. You can get the replacement CRTs ( tubes) from www.tvrepairworld.com
Jun 14, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
My husband fell into the television and the front screen popped out. Can we put it back in ourselves? It is not broken
You should be able too. You will need a torx #20 driver bit to remove the bezel around the screen. Carefully... The screen can be easly scratched
Oct 22, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
High pitch noise, no picture. GE 52" projection, Model D52GW12
Ur high voltage FBT the flyback tranformer,a big black block of plastic with a gray wire connected to a board.The cap it dead.The FBT it useally it dead too,arching noise FBT not holding the high voltage.
Mar 30, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Same problem. GE Model #D52GW12 Working fine then just caught on fire. Removed the back and found a part that said "Focus and Screen" on it. Can this be replaced or do you have to replace the circuit...
the flyback... very common for the ge version of the rca it222 you may also have to replace the horizontal output transistor. i have found at the shop the flyback and the transistor ussally all that have to replace
Apr 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12, picture is distorted and snaps
its either the HV splitter or the flyback which needs replacement. You can get both items at the following link with free instructions.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Screen
crt burn is common among projection tube tvs. crt burn is just that a burn in the phosper of the crt.. I know of only one solution for this. replacement of the burnt crts. tubes cost on average 250 apeaice and there are 3 then the labor... ussally the cost to do this exceds the value of set. these sets are around 800 to buy new.
Jan 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Looking for a part
Thompson is the company who handles parts for GE, and Global INC is one of their distributers. hope this get you closer cheers
Jan 21, 2006 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
138 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
