Question about Tomtom ONE 3rd Edition GPS
No voice The voice quit working. Can I fix?
  • thief Jun 16, 2008
    yeh hi guys
    i got no voices
    and when lookin a the file on the tom tom
    alot of files are corrupt
    can not back up
    lookin for a full re install or some thing
    hope to hear from some one
No voice
Posted on Jun 15, 2008
I have a Bell Office 600d digital voice recorder and Windows 7. I want to copy the recordings onto my PC, but when i try and open one of the files it says that the shortcut has been removed or deleted (i...
Hi Alana,
There is in all liklihood nothing wrong with your digital voice recorder. It was never designed to work with Windows 7 (any version). Try loading the voice files onto a PC with any one of the following operating systems:
Windows VISTA; Windows XP (Professional or Home); Windows Me; Windows 2000 (Professional); Windows 98 (Second Edition). It should function quite normally and download, so that you re-use the memory on your recorder.
Apr 25, 2011 | Olympus W-10 Digital Voice Recorder
VOICE turn by turn has quit working. How do I restore voice.
Check that the mute box is not ticked.
1. Press Tools, Settings, Language and then press Voice. Select a new voice.
2. If that doesn't solve the problem it may be that the voice file has become corrupted. Connect the satnav to your computer. Download and install webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 When it's installed it will look for updates to your satnav software. After this it will give you the option to download voices. Select the ones you want and click next. The voice files will be downloaded to your satnav.
When you've disconnected the satnav from your computer select the voice you want as described in paragraph 1 above.
Aug 13, 2010 | Garmin nuvi 750 GPS Receiver
Voice mail will work
You'll need to contact your cellular provider and have them reset your voice mail account. Ask for tech support and they will be more than happy to do it for you.
Mar 29, 2010 | Nokia 6061 Cellular Phone
Back ground music louder than voices watching movies on cable
Is this a new problem or always like this? <<<<<<<<
What is your speaker complement? The center usually carries the dialog.
Are the receiver and its speaker systems set up per the manual? Make it so.
How is the TV-related (Cable) audio entering your receiver? It SHOULD be from the cable box, digitally if available, NOT the TV. You don't need a Low-Fi middleman handling your audio.
Mar 05, 2010 | Denon AVR-3805 Receiver
My amp settings was all the way up...and i didnt even realize it... i messed up 2 of my 15s pyle drivver subs...is there any way i can open up the sub and fix it up or something? appreciate it if someone...
If your subs quit working then chances are you fried the voice coil and while anything can be repaired it most likely isn't worth the money you'd pay to have them fixed.
Nov 26, 2009 | Car Audio & Video
How do I activate the voice dial on my Nokia 6230i please?
At the menu screen,select menu and scroll down to contacts, hit select,then select names, find the number you want to add voice dial to, select details,select options,scroll down to "add voice tag" Hit select and follow the instructions.
One tip: when you program the voice call, you should be in the enviroment thet you usually use the voice dial. If you set it up in a quite place like your home and then try to use voice dial in a noisy place, it probably will not work. Also talking louder does not help.
Hope that helps. If not, you probably have a problem with the phone itself.
Latre....
Sep 22, 2009 | Nokia 6230i Cellular Phone
How do you wire up a dual voice coil lanzar 15 for 4 ohm?
Hello dexterchapma,
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
Hope this helps.
Jun 27, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Voice quit working
I assume you have made sure the volume knob on the right side of the unit is adjusted all the way up. Have you also made sure the volume icon has the volume up? Does the unit make any sounds at all?
May 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Tomtom ONE 3rd Edition GPS Logo
71 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
