Question about Samsung HCN653W 65" Rear Projection Television
Tv will not come on
I turn on the tv timer light blinks but tv never comes on, I hear the sound of it coming on but it never does.
    Scholar:
  • 137 Answers
Hello brexpress,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Posted on Jun 22, 2008
  • jryel Mar 05, 2011
    My 65 DPL has just started to not turn on via the controler. I needed to shut all elect. off and a rebobot. It restarted with a; will it worked for a week then got green artifacts. As you know the sansung is set up with a big audio system. I've replaced the bulb a few years ago and that does not seem to be the issue. Love the TV and would like to fix it beyond replacement. ANY IDEAS?
    Would think I could put a few $$ before the new replacement at 4k arives. I'm on a budget and love the tv any iddeas?
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
No Picture - Sound
I just had this problem fixed. In my case, it was because the insulation on the CRTs was cracked, and when it would warm up, the shielding would separate and would let 5000 volts arc across the main board. This, obviously, damaged the board. The tech didn't catch the arcing right away, so they replaced the main board twice before they used a high-temp RTV to patch the insulation.
The power-cycling was a result of the damaged board.
The point of this story is that the broken part may be a symptom of the real problem.
I hope this helps someone!
May 29, 2008 | Samsung HCN653W 65" Rear Projection...
No picture no sound
Probably, the selftest fails while turning on. If this is the case, press input&menu buttons at the same time for 5 seconds, then the green led will start to blink. Let me know how many times the led blinks.
Regards
Mar 01, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv will not come on
Sounds like the bulb is blown.
Oct 05, 2007 | Toshiba 52HM95 52" HDTV Projection...
Samsung HCN653W 65" Rear Projection Television Logo
73 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
