Question about Car Audio & Video
1993 volvo 850 GLT factory stereo only powers rear speakers. continuity exists between speakers & plug to back of deck. when front rear fader control is set to power front speakers no sound unless volume is set to maximum, and even then only a tiny amount of sound barely noticeable. Is problem in front rear fader control or actual output in deck to front speakers? How can I repair this problem without buying a new deck. I have considerable electronics knowledge and a digital multi-meter w/ohms,voltage, capacitance etc.?
    Genius:
  • 1,148 Answers
Front speakers could be blown
Posted on Nov 03, 2010
I had some kicker 6x9 cs693 installed in my 2002 camry rear deck and when they returned the car the spearkers are not producing much sound or bass. I am using factory stereo and also the factory 6x9 on...
first check to see that the fader is not programmed to the front speakers fading it rear might solve your problem, second if your stereo has a 4 ohm load requirement at the output and your new speakers are 8 ohms this will cut the power output in half, your best bet is to get an amp if these do not solve the problem.
Feb 27, 2015 | Kicker Car Audio & Video
Where do I find the DLC Connector location for my 1993 Volvo 850 GLT? Where can I purchase the Volvo adapter for the OBD I and/or II readers?
hi, i know a shop, they supply the good qaulity and good aftersales volvo adapter for obdi or obdii. you can look here, hope help you.
Jul 01, 2011 | 1993 Volvo 850
1993 Volvo GLT 850 Electrical things won't work
I'd be taking the dash apart looking for burnt wires in a harness, so you will likely have to take the outer cover off some of the bundles. Start tracing back from the plug in for the radio. Hope this helps.
Sep 11, 2009 | 1993 Volvo 850
I need to know the audio wiring for a 1993 caprice classic
1993 Chevrolet Caprice Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
pls rate
Sep 09, 2009 | 1993 Chevrolet Caprice
I have Volvo 1993 850 GLT odomters salvaged from the junk
Short of buying new, there is no known way of clocking it.
Jul 09, 2009 | 1993 Volvo 850
Front speakers work intermittently. Rear speakers work fine.
You have a short in the speeker wire probably in the door.
May 07, 2009 | 1993 Volvo 850
Code stereo volvo 1993 850 GLT
If you need the security code, you need to call a Volvo dealer and give them the VIN number, provided it is the same stereo the car came with.  Most dealers will do it for free, if you can't find one, call Boston Volvo Village.
Feb 12, 2009 | 1993 Volvo 850
1993 volvo 850 glt
Have you made sure the rotor is turning in the distributor, as this sound like a cambelt failure.
Sorry to bear bad tidings if this is so.
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Please remember to politely rate my effort!
Jan 21, 2009 | 1994 Volvo 850
My volvo 850 GLT
the factory plug wires last about 200,000 miles/if the cars runs ok other than stalling at idle and has no check engine light on the the next step is on the drivers front of engine remove the air intake hose and clean the throttle body with carb spray cleaner and remove the idle control valve mounted to the front side of it and also flush it out
Aug 27, 2008 | 1993 Volvo 850
Car Audio & Video Logo
108 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
