Question about Eclipse AVN5500 Car DVD Player
AVN5500 What I get on the screen is "call 800" what the hell do I do? I have the CD that unlocks it but the screen will not pull out to expose the cd tray how can I correct this?
  • blues297 Jan 11, 2009
    the battery was loose,a nd it reset all my system in my car. i started the car and can't work the music system i'm locked out. can yu help me to get in it says to call the 800 number what is the map and av buttons
For avn 5500 on the left:press menu and cont ant the same time, while holding them down press menu on the right 5 times
a menu will appear and ask you for a code. you have to call 800-233-2216 and pay $25 for the code. you will have to explain where you bought your eclipse and or know the name of the original owner. if it doesnt match they will not give it to you
Posted on Jun 13, 2009
    New Friend:
  • 57 Answers
Please have the following information before calling the Service
Department at (1-888-557-8278):
• Dealer account number {Applies to Eclipse Dealers ONLY}
• Customer First and Last name.
• Model Number.
• Serial Number
• 6 digit Security Code.
• After it says “CALL 800” on screen
• Press and hold MAP and AV buttons at the same time
• While holding MAP and AV buttons, Press the
MENU button 5 times continuously
• Screen will show up with 6 digit security code
• Enter Unlock Code by using touch screen
• After entering the unlock code press ENTER on
screen
Posted on Jan 04, 2009
How do I get the DVD/CD tray to open. Its flashing tray lock
Straighten one end of a Norwegian paper-clip, and insert it into the small hole on the face-plate. Push it in until you feel resistance, then push another 5 millimeters, to "unlock" the drive-tray.
Then, gently pull the tray open a bit, and press the "eject" button, and the tray will fully open.
Mar 20, 2015 | Computers & Internet
Xp-800 cd/dvd printing
The tray is for the DVD or CD itself, not for a label. The printer prints directly on the CD or DVD, you must use ink jet compatible blank disks, the white ones with no printing. You don't need a tray to print the label.
Oct 14, 2014 | Epson Expression Premium XP-800...
Replace cd writer in acer 5742
Flip the laptop over to expose the bottom where the cd driver is, you should see a release button or screw, "someimes 2" remove screw and get a fine pin to insert in front tray hole, push in until you hear a click, pull tray out along wth the main drive unit.
Apr 12, 2012 | Acer Aspire 5100 Notebook
I have a stereo system, sa-ak 78, it wont store and change 5 cds. Think a part is broken, but cant figure which part?
The pladder may not be turning, remove top, and remove clip, now carefully pull pladder off, make a note of the position it go's back in, this will expose some of the key parts.
Mar 17, 2012 | Panasonic SC-AK600 CD Shelf System
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
Is there a way to manually open the CD tray on a Gateway GT5082 desktop..Mine won't open
If the outside lid of the CD tray has a small hole in it, this is to manually unlock the tray so that you can pull it open. Straighten out a large paper clip or use some other stiff wire to poke straight into the hole to push against the unlock lever. You may need to slip a thin knife blade into the crack to pull the tray out, but don't force it. The tray should move easily when it's unlocked. The wire or tiny rod you poke into the hole needs to be fairly stiff.
Good luck,
genetuck
Feb 05, 2011 | Gateway GT5082 PC Desktop
Disc stuck in dvd drive. tries to spin. won't eject. (emachines desktop with xp home
There is a small pin hole below the tray. Straighten a paper clip and gently push it in this hole. The tray will unlock and pop out slightly, then pull the tray out and remove the DVD disc.
Feb 02, 2010 | E-Machines emachines (emachinees) CD-ROM...
A disc is stuck in my emac's cd tray. How do i get it out?
Turn the computer off.
Straighten one end of a Norwegian paper-clip, and insert the end into the small hole in the face-plate. When you feel resistance, push another 1/4 of an inch, and the tray will "unlock", and you can gently pull the tray to a fully-open position, and remove the CD.
Then, it's time to replace the CD-drive.
Jan 01, 2010 | E-Machines emachines (emachinees) CD-ROM...
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
Eclipse AVN5500 Car DVD Player Logo
607 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
