Question about Toshiba 1GB USB 2.0 High-Speed Flash Drive 1 GB USB Portable (PA1399U1MEMFT) Drive
Cannot open thumbdrive, Requesting us to chose the a program to open the thumbdrive programs.
    Genius:
  • 1,148 Answers
Check website of maker of ur flash driver for driver downloads and support,,they should be able to help,,also try when it tells u to choose program,,,try jus closin that and go to my computer open it like that
Posted on Nov 03, 2010
    Genius:
  • 1,325 Answers
Try using another computer to open the thumb drive. is the computer USB 2.0 compatible ?
This is my daughter's computer. It freezes, it shuts down, it skips characters when typing. She is a senior in high school and is getting so frustrated trying to do her homework!
Download a copy of CCleaner and run a cleaning on it. After that use the registry cleaning function on it (making sure to save a back up of the registry of course). Do this once a month.
There is a RAM testing program that you can download and install onto a thumbdrive that will test your RAM to make sure if isn't faulty. Memtest86+ is a good one. You can download it here. I have used the "Auto-installer for USB key" to create a thumbdrive that will load the program when you start the computer. Once you have installed it on the thumbdrive, restart the computer with the thumbdrive in, and set the BIOS to load the USB before the HDD in the boot device order. (generic directions here) If you can, test only one stick of RAM at a time. This was if there is a problem detected then you will know which stick of RAM is the troublemaker.
Finally, download a good disk defragmenting program and defrag the hard drive.
Sep 26, 2012 | ASUS A53U-ES21 15.6" Windows 7 Home...
Tip
How To Remove A Virus From Your Computer
Requirements: On an uninfected PC connected to the Internet, download the following programs to a thumbdrive. We will need this to fix the infected computer.
Instructions:
  1. Shut down the computer as soon as you realize there is a problem. Pop-ups, program errors, dll errors, fake Anti-Virus scanners, and similar are signs there is a problem. Shut down the computer normally, or hold the power button in until the computer shuts off.
  2. Power on the computer, and hit F8 before the Windows Startup screen appears. Select Safe Mode.
  3. Login if asked to, if not select Yes to continue.
  4. Click on the Start menu, select Run, type msconfig and press Ok, or type msconfig into the Start menu search box and press Enter.
  5. Under the General tab, select Diagnostic Startup. Press Apply.
  6. Under the Services tab, check the Hide All Microsoft Services box, and uncheck any services you don't recognize in the window.
  7. Under the Startup tab, select Disable All. Press Apply and Ok.
  8. Don't restart the computer yet.
  9. The System Restore Utility backs up selected files automatically to the Restore folder. Quite often are infected files stored there as backup files, and many Virus Scanners are unable to delete these files. If you suspect your computer may be infected, it is recommended that you disable the System Restore Utility to remove the infected files from the Restore folder.Select your OS for directions on how to disable the System Restore Utility - XP, Vista, 7
  10. While in Safe Mode, insert your USB thumbdrive and open it in My Computer.
  11. Open Combofix.exe, select Ok when it asks. Let Combofix scan and remove any infections it finds. It should restart the computer when it is done. When it restarts, boot up into Windows normally.
  12. Login if asked to, open your thumbdrive in My Computer again, and run Combofix.exe once more.
  13. Open up SmitFraudFix.exe from your thumbdrive. Press any key to continue when asked. Type 2, and press enter. When the scan is complete, restart your computer.
  14. If you had a fake Anti-Virus Scanner infection, open up Remove Fake Antivirus.exe from your thumbdrive. Press Start, and press Yes. When the scan and removal is Complete, restart the computer again.
  15. Install Microsoft Security Essentials, or your choice of Anti-Virus Software when the computer returns back to the desktop.
  16. Restart if asked to, and when the computer restarts, run a Full Scan in Microsoft Security Essentials.
on Feb 25, 2011 | Computers & Internet
Tip
HOW TO ACTIVATE YOUR WINDOWS XP SP2 COPY (Without programs)....!
Dear All,
It is a way to make windows original, and you can download programs Microsoft and make updates.
lets start:
-open start main,then chose Run and write regedit and Click OK.
-now it opens your system registry editor Go to the existing basic and chose Edit(after the file menu) edit then chose Find.
-Type in the writing OOBETimer, And press the search for the next Find .
-When find this value will be in the form of a blue icon,Put it opens twice each square liberalization value
Look for value FF and Wipe and write instead means 00 (zeros).
-Click OK and then exit the program.
-Now click Start and go to run the operation
And paste there is the following:
C:\WINDOWS\system32\oobe\msoobe.exe /a
-Click OK, Show you screen options reactivate Windows ,Chosen option number one.
-Show you a new page
Click on the button to change the key to the product or ChangeProduct key.
*now enter this serial
B7R7P - J63JP - 2J7VH - W3TDJ - PDP7T
-Then click update and then exit the program .
-now close all programes and reboot your computer.
-Surely wants to really make sure your original xp ? go to run and open :
-Tell you that the product has been activated
Now copy registered go and work updates automatically to your computer.
note:- just make sure to backup your registry before you gona do..
on May 27, 2010 | Computers & Internet
Hi there, I have just installed 7.10 and I would like to upgrade to the Ubuntu latest version... How can I do that? Can I dowload it or should I order the install CD? Many thanx,*
11.04 is the most stable and current version. You can upgrade from 7 to it with a thumb drive, and an installed program.
Go to the Ubuntu Website and download 11.04 iso.
Download and install UNetBootin.
Insert your thumbdrive, format it.
Open UNetBootin.
Select "Disk Image" then locate the location of the 11.04 iso you downloaded.
Then at the bottom, select your thumbdrive, and click OK
This will then get your thumbdrive bootable, and install 11.04 too it.
Once that's done. Shut down your computer, boot from the thumbdrive, and follow the upgrade instructions.
Best part, about "Upgrade". It'll 99% of the time keep your documents intact and just update the software.
Sep 25, 2011 | Canonical Ltd. Ubuntu
Cannot open any programs, keeps asking "chose
Good day. Your correct my friend. Usually if a program that is usually used in a computer then suddenly uninstall, all files that uses that program will show that message your getting because your computer cannot open them . What you need to do is to install the program or software again. For example, if your downloading a file in pdf you need to download adobe reader or if you are download a video file you need to download and install the player like mediaplayer, divx. You just need to make sure what type of file your downloading and you can select the option to check the internet for softwares that can run this file. Hope this information help you a bit. Have a great day
May 26, 2011 | ASUS Computers & Internet
Hi. my pc was hacked and I saved software programs such a AVG antivirus onto a thumbdrive. Now that I reconfigured my pc, I am ready to transfere the AVG on the thumbdrive to pc, but it is not offering a...
Looks like you simply copied the exe file of the particular program or just the folder of AVG from programs. This is not the procedure to take a backup of any software. It is best for you that you download the AVG free antivirus again from the internet.
Sep 17, 2010 | Computers & Internet
Set association to open a PPS slide show from Email
Right click on that pps file:
1. Open withh
2. Chose default program
3. Browse and hose Power Point
4. And check box with (Always use selected program to open this kind of file
Jul 10, 2010 | Dell Studio One 19 Desktop Computer (Intel...
Not reading all photos on the thumbdrive.
From my research I see this device only supports JPEG/JPG formatted pictures. Please ensure that all pictures you wish to display are this format. You can convert the file format using MS Paint or any of your favorite picture editing programs.
Good Luck!
Jesse
Jan 06, 2010 | Philips (9FF2CME/37) Digital Picture Frame
Need GameBridge to install on a computer without a cd drive.
You need to utilize a program that will allow you to create an ISO copy of the CD to the thumbdrive. When you do this all the files on the USB should be removed BEFORE the copy.
Jul 25, 2009 | Adaptec GameBridge AVC-1400 (2179900)...
Unable to open YouTube
simply update the programs that youtube is requesting. if it still doesn't work, make sure those items that the page is requesting are turned on, and not disabled by security software. also, check with the browser itself to make sure those programs are not turned off.
Jun 11, 2009 | YouTube Videos
Computers & Internet Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
