Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
Ge 52 inch tv green light flashes 3 times then shuts off
  • lizhamad
    lizhamad Sep 19, 2012
    I just tried the same thing on my TV and it turned right on!!! I couldn't believe it! A TV repairman wanted to charged me a 30.00 trip charge plus he said my capacitor had to be replaced. I pulled out the hairdryer and 3 min. later the TV was working perfectly!!!
In searching for the same answer I've found the two following solutions. The first one definitely looking the cheapest by far. I just read it so I haven't tried the first option yet.
1st option: THIS SOUNDS CRAZY BUT I JUST DID IT ON MINE AND IT WORKS!!!! REMOVE THE LOWER REAR CASE ( ITS THE LARGE BLACK PLASTIC COVER WITH THE VENTS ON SIDE ABOUT 15 SCREWS IT WRAPS AROUND THE LOWER BACK OF TV) USE A HAIRDRYER AND HEAT UP THE LOWER LEFT CORNER OF THE GUTS(AS LOOKING FROM REAR) FOR 5 MINS OR SO THEN TURN IT ON. MAKE SURE YOU UNPLUG UNTILL READY TO TURN ON. 2nd option:
Your convergence IC's have burnt out.
Is the Tv worth saving? is it bright and clear? was it good (when it worked?)
if the answer to all of these is yes, then you have a few choices. If any of these are not true, then you should just get a new tv.
Your choices are:
If you are good at soldering, then you can attempt to replace the IC's yourself. (with all of the parts handy, it should take 1 hour)
If you aren't good at soldering, then you can have a friend do it for you, or you can have a mechanic fix it. (tell them that its the convergence IC's that went bad. (pay no more than $200 for the job).
here is what they look like:
http://farm4.static.flickr.com/3021/2785697590_4b74e0a58f.jpg
(the number may be different)
Here is an idea of what your tv looks like on the inside:
http://img523.imageshack.us/img523/7862/img1207ky2.jpg
(btw, to disconnect "those" all you have to do is lift up underneath where the white thing bridges the two boards and they will pop up.)
A word of the wise, do NOT open up your tv and attempt this if you don't know what you're doing. There is extremely high voltage inside, even when it's unplugged......so don't get shocked!!!
Posted on Nov 08, 2010
52 Inch RCA TV Model HD52W55 does not turn on green power light blinks 3 times but does not turn on. ive got it to turn on once before, and left it on since, accidently shut it off and cant get it back on,...
The best assumption, at this point, is that the power supply board has died. You can buy a replacement unit from the link below and have it professionally installed.
Power Supply
Aug 28, 2011 | RCA HD52W58 52" TV
TV will not turn on
The power supply will need to be replaced. This is extremely common now days.
Sep 23, 2009 | GE 32GT740 32" TV
GE 52" will not power up - green light flashes 3 times
Replace CP150 and CP114 and CP120/ You can get the caps with instructions at the following link. They do have a minimum order amount of 10.00 so you may need to order an extra capacitor to total 10.00 but shipping is free. The parts are listed under the RCA parts category,
http://servicemanuals.vstore.ca/
Feb 07, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Green light flashes
Same thing here....RCA tells me to count the times the light flashes as it apparently is set to "tell" you what the problem is.......3 to 5 flashes means your lamp is messed up.....they are over $300 to replace!
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ge d52gw12
Maybe you can replace the flyback?? if you can solder then give it a shot. get the manual and more help here http://servicemanuals.vstore.ca/
Feb 13, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
1,107 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
