Question about Cameras
I have a Kodak play touch, and when i record it will record for Approximately 5-10 seconds, then a screen comes up saying an error has occurred without telling me what i need to do to correct it. please help
Most likely it's a memory card error. Your memory card is either defective or corrupt. Try shooting video without the memory card in and see if you get any errors. Then put a different memory card in and see what happens. If after all that you don't get any errors than it is obviously your memory card that was corrupt.
Posted on Jun 06, 2011
HOW DO I FIX THE ACCESS DOOR ERROR CODE 3501?
The Kodak support site says:
To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
If the error continues, contact Kodak at:
http://www.kodak.com/go/contact
May 18, 2014 | Kodak Office Hero 6.1
Formatting problems
older mp3 players cannot handle bitrates higher than 128 and you should not be recording them with variable rate either. I recomend, deleteting the card and start new with a standard bit rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 14, 2014 | Audio Players & Recorders
Screen says "Printer error."
Welcome to Fixya
If the error occurred when you were trying to use a feature of EASYSHARE Software:
  1. Run the Repair utility:
    1. Select Start > Settings > Control Panel > Add or Remove Programs.
    2. Click KODAK EASYSHARE Software.
    3. Click Change.
    4. Click Next.
    5. Select Repair, then follow the instructions.
  2. Try the feature again.
If the error occurred when you were installing or upgrading EASYSHARE Software:
  1. Uninstall your current version of EASYSHARE Software:
    3. Select Remove.
    4. Follow the instructions to remove the software.
  2. Go to the Clear Utility for KODAK EASYSHARE Software at www.kodak.com/go/clear, then follow the instructions to run the utility.
  3. After restarting your computer, go to KODAK EASYSHARE Software at www.kodak.com/go/easysharesw, and install the latest version of software, free of charge.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 23, 2011 | Computers & Internet
The vids on my Sony DSC-T90 won't play and I can't record. The camera says' "file error"
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Not able to record or play :
This error may occur in any of the following circumstances:
-The Memory Stick® media is not inserted properly.
-The Memory Stick media is not supported for use with the camera.
-The Memory Stick media may be faulty.
Mar 13, 2011 | Cameras
U61 error code on Panasonic DMR-ES35V DVD recorder/VCR
Replace it, it is not cost wise to have it repaired.
Jan 01, 2018 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't record DVD+RW and DVD+ Disks...PLUS
Firstly, you need to finalize the -R disk recorded by and in your unit before it will play back anywhere else.
Secondly, the DMR-ES10 does not support +RW, only -RW.
Finally, I have never heard of a +D. Do you mean +R? It is likely that you have a corrupt disk; change it.
Mar 11, 2009 | Panasonic DMR-ES10 DVD Recorder
Whats error code 3501
According to Kodak, that error just means the cover was open. I noticed when I print a diagnostic sheet that error shows up whenever I change the ink.
Sep 02, 2008 | Kodak ESP 5 Printer
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Cameras Logo
285 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
