My panasonic pt 40lc12 40 inch was on and watching cartoons and made a loud pop and then turned off what is the problem with it just a lamp please help
Re: My panasonic pt 40lc12 40 inch was on and watching...
Check the lamp. It should be a square door for the lamp on the side, back or the front of the TV. Read the user's guide. Make sure to turn the TV off when removing the lamp!. Good luck. Nour Sabre
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Amazon.com, Inc.
Rating: 3.8 - 30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
carefully take the lamp cover off, and see if there is any glass pieces inside. if all looks Ok, then unscrew the lamp housing and remove the lamp. check for any damage. be careful not to damage the lamp or bump it. These lamps generally contain mercury vapour, so try not to inhale anything if it's broken.
Hi, If lamp in tv has not been replaced in last 3-4 years then check lamp and replace it. Did tv showed lamp replacement requires warning/ message on screen before going to shut down? Did you hear any pop sound inside tv when it get shut down? that pop sound could be lamp that got broken. Let me know if you have additional question. Thanks.
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Hey I heard This same loud pop well playing games on my Pt-AE700U
It was the lamp, once i replaced it i had the saem problem you have to reset the lamp hours on the main screen
I can't tell you how to fix this set, but I can tell you that its not a "lamp" issue as this doesn't have a lamp. Its a 3 picture tube projection TV. the three tubes are in a red green blue format, and average about $175 for each one, not including the labor to install them. your problem, may not be the tube, but just a power supply problem, but there is a chance it is.
This unit has a chonic issue with corruption in the eeprom that causes spots and shadows. The correction is to find some service center that has the jig to hook up to your unit and correct the eeprom. This is an extended warranty issue with Panasonic and if you contact them they should be able to refer you a qualifed service center and Panasonic will pay.
