Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Air exhaust hose gets extremely warm
We've had this problem from day 1. Although the unit blows cool air, the heat coming off the exhaust hose cancels out the effect and if anything makes the room warmer.
We have both hoses connected, and the other one (air inlet hose) stays cool.
Any advice is appreciated!!
    Problem Solver:
  • 9 Answers
The Pinguino's exhaust pipe has to be attached to the window bracket to direct the air hot air out of the room, otherwise the room can't cool properly.
The owner's manual has several troubleshooting remedies for you to try:
1)  If the window is open, close the window. 2)  If there is a heat source in the room (burner, lamp, etc.), eliminate the heat source. 3)  If the exhaust hose is detached, connect the exhaust hose.  (My recommendation is to connect the exhaust hose to the window bracket and direct the air outside.) 4)  If the air filters are clogged, clean or replace the filters.
Remedies that aren't mentioned in the manual, but you might find helpful:
1)  Make sure that there are no kinks in the hose, and that the hose either remains straight or has a gentle curve when directing it into the window bracket.
2)  A sunny window reduces the maximum power and efficiency of the unit.  Placing it in a sunny window reduces your BTUs by at least 600, which means the maximum square footage of cooled space is reduced.  Cooling a kitchen requires at least 4,000 BTUs alone, which is nearly half of the unit's BTUs.  Try to place the unit by a window that receives minimum to no direct sunlight.
Finally, stating the obvious, if the room isn't cooling, the room is too large for the unit.  The PACL90 cools up to 400sqft.  Bear in mind that the air from these portable air conditioners cannot move around corners very well, so try to set it by a window in the central part of the room.
Posted on Jun 25, 2008
    Genius:
  • 1,554 Answers
Replace the hose with a insulated housing hose. like the ones in your attic.
though you have to buy it in 25 ft sections.
or wrap that hose in insulation.
and putting a strong fan at the end of the hose will help it **** out the heat. then you can run the hose further away.where you won't hear the additional fan.
the best is just forget the portable and sell it .
they **** energy and provide little relief.
a window or wall unit produces much better air flow and btu power.
that portable is for folks who work in a hot garage area ,not for cooling a room at all.
Posted on Jun 13, 2008
Air conditioning unit blowing warmer air even when unit is set on 70 and then will blow for 10-15 minutes and then cut off for 5-10 minutes before coming back on again blowing warm air.
If its a window unit, pull out of window get to the front fins might have to remove a few screws on the sides of front and spray out with a hose be careful not to get control box wet.spray fins and wheel inside, dump water out the back or side, put back in window it should start blowing cold air if not then its time for a new one.but sounds like its getting over heated
Aug 28, 2017 | Heating & Cooling
I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air...
Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
Oct 14, 2013 | Whirlpool ACE244XS Air Conditioner
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
How does the heater part of the CPN12XH9-E work? Does the hoses need to be in window still?
Yes, hose needs to connect to outdoors, since it operates as a heat pump. You'll notice cold air blowing out the exhaust when in heating mode, and hot air blowing out the exhaust in cooling mode - unit exhausts opposite of temperature you want.
Jun 13, 2011 | Haier HEATER CPN12XH9 Air Conditioner
My rv air condition also has heat, the heat in it is not getting very warm. So days it will burn u out of it and some days it just blows cool air! Any suggestions. It is a dometic
Check the following if you're unit is not giving heat.
1. Keep temp setting +8 degree from your room temp 2. Keep mode in "Heat". And check the click sound in RV when you turn to heat mode. If one failed out of three your unit will not supply heat.
Dec 15, 2010 | Heating & Cooling
Hi, two days ago I bought a Danby Premiere DPAC13009 portable AC unit. It worked on the first day reducing the temperature from 32C in the room to 26C in a few hours. Although now there is no cold air...
Comperssors have a thermal overload. If there is a starting problem or low on freon the conpressor will shut down until cooled off. Try restarting and listen to compressor.
Sep 03, 2010 | Danby Heating & Cooling
Do we need to use both hoses?
You could draw the air from inside however the system works much more effeciently with 2 hoses.
The air that is drawn into the unit and heated then exhausted back outside. If you don't use the second hose all the air that is exhausted will have to be drawn in around windows and doors or othe voids in the area. This would draw in warm moist air that would then have to be cooled and dehumidified.
Jul 19, 2010 | Danby DPAC120061 Portable Air Conditioner
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
602 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
