Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Is there a reset button for the Hoover turbo cyclonic model #UH70055 and how do I take it apart to change the belt?
Kazong
  • 152 Answers
SOURCE: How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
Posted on Jan 17, 2008
SOURCE: how to change belt on
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=841267
Generic problem for all Vacuums
How to change belt on
Posted by tbellme on July 27, 2008
How to change belt on Hoover Turbo 4600
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 28, 2008
  • 97 Answers
SOURCE: Hoover wind tunnel cyclonic U5780900
Well, the V belt is normally fairly slack until the handle is dropped below 45 degrees, which is when the belt tensioner assembly drops into place. If turning the brushroll by hand when the vacuum is in this position fails to rotate the self propel pulley, the tensioner is not functioning properly and will need to be replaced.
Also ensure that the brushroll can spin freely by hand, as these have a tendency to melt at the ends and seize the brushroll. I have also seen the groove that the v belt fits into melt itself out of round, which can cause the same symptom as you're describing.
Keep in mind as well that while the rubber belt may appear to be ok, it does have to be replaced every 3-6 months whether it breaks or not. Even though it hasn't broken, if you were to hold it up against a new belt, you would see that the old one has stretched significantly: which can decrease the machine's ability to rotate the self-propel transmission pulley and, in turn; the brushroll.
Feel free to contact me with any further questions.
-R
Posted on Oct 02, 2008
dragonsthatk
  • 547 Answers
SOURCE: hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Posted on Feb 12, 2009
  • 251 Answers
SOURCE: hoover turbo cyclonic only 12 weeks old stopped
try changing the fuse in your plug ( uk ) if this fails to fix it , have it repaired under warranty
print-icon.gifPrint/Download
Warranty The Platinum Collection Lightweight Bagged Upright plus Portable Canister warranty covers parts and service of the cleaner for six years.
As a member of the Hoover Platinum Collection, the Platinum Collection Lightweight Bagged Upright warranty gives the owner access to the exclusive Platinum Collection member services line for the best in customer service.
TTI Floor Care North America
7005 Cochran Road
Glenwillow, OH 44139
1-877-MY-PLTNM
Posted on Nov 15, 2009
Testimonial: "thanks"
Brush not spinning on my montiss turbo 850 vacuum. Hoover suction ok. Have took apart and deluded and still not working
Check the belt. If the beater bar will spin with the belt loose but not spin under power, the belt may be slipping.
Jan 28, 2015 | Hoover Vacuums
Belt issue
Check the switch to the brush bar it might not be in the right position it needs to be in to run or not run should be in a little slot that turns it on and off
Apr 18, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover zen whisper multi cyclonic canister vacuum belt removal
just underdo the screws from the bottom of the hoover head (where the brush rotates from) I think from memory there are about 8 screws carefully price the plastic apart use a flat headed screwdriver as sometimes there are retaining clips and you should be able to access it hope this helps
Apr 05, 2014 | Hoover Zen Whisper Multi-Cyclonic Canister...
How to change belt on hoover savvy vacuum
How do I change the smaller brush belt on a Hoover Windtunnel Cyclonic?
Jan 11, 2010 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Roller bars on bottom not rolling
The belt has probably broken. Hoover says that the belt on this model should last the life of the vacuum, but that is rarely the case. They do wear and break. Changing the belt is simple and the belts aren't to much. You can get a replacement here:
Savvy Replacement Belts
Oct 30, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Hoover savvy will not move
the reset button is in the handle, under the cover for the switch. remove the two screws and pop apart. you need to pull up the little post under the lever switch, and push it back down. hope this works for ya.
Jul 01, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Hoover mach6 the brushes don't turn
Replace the skinny belt, but here's the kicker. turn the belt inside out so that the writing is on the inside and sits against everything. Thats what I did and I have used it once and it worked well, Lets hope it'll keep working.
May 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
611 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
