Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
B & D flip handle electric corded mower
Help!! The handle fell off. It was a little wobbly, like something was missing somewhere, but as I flipped the handle over springs flew out and one bolt. Don't know where to begin to try to fix it, down in that slot.
Jellybeanie
  • jellybeanie Jun 23, 2008
    Guess I wasn't clear. The lever did not come off; the whole handle came off from its attachment to the mower.
    Champion:
  • 313 Answers
Do you mean the orange lever came off. if thats the case you need the switch housing assy & a spring. the lever was held by the plastic housing pin or pig. some times the plastic pin worn out before it breaks.
Posted on Jun 14, 2008
My Honda mower won't start and is really hard to pull the cord
take it outta gear,or check the belt or flip it up on its side and see if something is wrapped around the blade or shaft,also check the starter and make sure it isnt bound up
Jun 12, 2015 | Honda Garden
Oven does not heat
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 18, 2014 | Frigidaire Ovens
Top cord handle fell off
The spring is part of the silver power cord clip that you flip around at the top of the handle to release the power cord that has been stored in a coil sour the fixed position plastic hook at the bottom of the handle and this one at the top. There is a long silver screw that goes through a washer then through this clip. The clip is in two parts, the hook or clip that rotates and a saddle that is stationary against the handle. The spring then goes on the screw under the saddle and finally is skewed into the handle.
Mar 16, 2014 | Riccar 8955 Upright Vacuum
How to fix a wobbly ceilng fan
wobbly cieling fan
1. make sure all mounting screws between the fan and the ceiling are tight. There is probably an electrical box mounted in the cieling that the fan is screwed into. I would turn the fan light on and then keep flipping breakers off, on at a time ,to see which breaker turns off the fan light. leave the fan light breaker off and you can unmount the fan from the cieling electrical box. The electrical box may have several holes in it for mounting screws and prehaps there are some holes left empty in the box that you can put more wood screws into to help keep the electrical box more firmly mounted and that may help lessen the wobble.
Its ok to bend the electrical wiring aside to put more screws in. Just be reasonably gentle with the wiring and then bend it back somewhat to where it was before you started. make sure that wiring does not get pinched between the fan and the electrical box and that all wiring resides inside the box.
#2 This is harder to do. you need to balance the blades for the fan ,similar to how a lawnmower blade is balanced after sharpening and before remounting the lawnmower blade on the mower. also kinda like balancing a car tire. I have a lawnmower blade balancing fixture that i bought at the lawnmower shop, but i dont know if there is a fan blade balancing fixture that you could buy from somewheres. Maybe try google.com,bing.com or ask.com and type into the search box fan blade balancer
or fan blade balancing fixture or fan blade balancing jig.
PLEASE read the directions or SPECIFICATIONS before you buy the fan blade balancer, only to find out that it only fits 9 inch diameter fan blades, and your blade is 2 4or 36 inches long.
The balancer may have to fit a certain diameter hole at the center
of the fan blade. When you finally find out which side of the fan blade is heavy, you have to grind , with an electric grinding wheel, some material off the heavy side of the blade so that it is the same wieght as the light side of the blade.
Try to imagine a cone shaped center[like step drills] like the capital letter V ,only up side down, so that the point is up. ON the underside of the inverted V is a needle tiped post that upside down V can pivot in any direction on. The hole in the middle of a lawnmower blade is centered somewheres on the outside of the inverted V, depending on the diameter of the hole in the lawnmower blade. The heavy side of the mower blade will go down and may touch the level asphault or the table top, depending on where you placed the balancing fixture. THen i would grind off metal until the heavy side can up to be level with the light side of the mower blade and it was considered balanced.
an appliance repair parts store may sell fan balancers, but if the would fit your cieling fan, better ask before you waiste your money on something that wont work for what you want.
Try calling up customer service of the manufacturor of your ceiling fan and ask about repair service for your brand fan.
see what repair service has to say, im sure many others have asked them about wobbling fans.
so they should have all the answers down pat.
Two more thoughts.
1.
.MAKE SURE ALL SCREWS THAT HOLD FAN BLADES ON TO THE HUB ARE THERE AND are TIGHT. one loose fan blade mounting screw or one missing fan blade screw will unbalance the whole thing and cause wobble.
2. the fan motor shaft bearing could be worn out or round or even egg shaped. If this is the cause, the motor must be diaassembled and new fan shaft bearings installed or the fan motor must be replaced.
good luck and have fun!
Sep 22, 2013 | Hampton Bay 24002 Ceiling Fan
How do i tighten the blade on a black and decker MM575-18
Hi Kevin,
User a pair of channel-locks to grab the square spacer below the nut. Then tighten down the nut using wrench.
May 07, 2012 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Triped cb
Make sure you are using an extension cord that can handle the amperage. If so then you've likely got an electrical short somewhere. Your extension cord should be at Least as large as the cord on the mower or larger.
Nov 20, 2011 | Garden
I have an electrical lown mower model LM 110 that as a broken plastic part under the blade but I don't have the manual to find the part number. Can you help me ?
IF is it a square plastic washer with 2 "wings\nocht" in the middle you can find at their servicenters because is a very common part and all the Black&Decker mowers use the same one. It holds the blade so you can thighten the nut.
Sep 18, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
What ingages blades ,blades not engage
On most riding mowers flipping the handle to engage the blade causes an idler pulley to engage the drive belt, which takes up the slack in the belt and pulls it against the drive pulleys. A few odd-balls have an electric clutch to engage the blades.
Jul 10, 2009 | Garden
Needle replacement...missing part?
To replace the stylus (N-6516 from your Sony dealer)
1.Turn off the amplifier
2. Protect the stylus with the stylus cover (it flips down 90 degrees)
3. Grasp the stylus holder (exposed when cover was flipped down) and pull it away from the cartridge body
4. Insert the stylus by pushing it in to the cartridge receptacle. Flip the stylus protector up.
Nov 24, 2008 | Sony PS-LX250H Turntable
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
83 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
EugenesDIYDen
EugenesDIYDen
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
