There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When
your dishes are not being fully cleaned, quite often a faulty water
inlet valve is to blame. Test your dishwasher's water inlet valve, and
if it is no longer functioning as it should, you will have to replace
it.
Water temperature is a key element in achieving clean dishes. A
dishwasher's heating element is not designed to heat the water that
enters it. Rather, the heating element is designed to maintain the heat
of the water that enters the dishwasher. Its a good idea to run the hot
water in your sink for a couple of minutes before you run the
dishwasher. Just to make sure the water is nice and hot before it enters
the dishwasher. If the water is unable to stay hot, it can adversely
affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large
particles of food and foreign objects away from the pump. Many of the
newly-manufactured dishwashers have self-cleaning filters, and routine
cleaning isn't a concern. However, some other dishwashers need to have
the filter removed and cleaned regularly. If the filter or grate is
clogged or blocked with debris, it may interfere with the normal
functioning of your dishwasher
