Question about Fahrenheat FFH1615 Heater
The thermostat switch on my old Fasco heater is fused togather and I need to replace it. It has this number stamped on it "AP 22" and it needs a screw mount at the base of the shaft that turns the heater on and adjusts the heat level. Is there a replacement available? GHK at cgkramer@windstrream.net
4 Suggested Answers
SOURCE:
Therinnaiguy
  • 1420 Answers
SOURCE: Fahrenheat 4000 watt wall mounted heater shuts off and needs reset
Sounds like a bad temperature control switch. If it looks like it can be replaced, check with Johnstone or Grainger Supply company to match it up. Google it for their websites.
Posted on Dec 07, 2007
Buffalo12980
  • 625 Answers
SOURCE: fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Posted on Dec 09, 2007
hotuna
  • 288 Answers
SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
Thermostat will not come on, therefore unit will not come on
Your thermostat is probably wired directly into the furnace to supply the 24V to power the stat. You have to make sure you're getting 120V into the primary side of the transformer, and 24V out of the secondary side. If you've got voltage in and nothing out replace the transformer with one of the same voltage, and same or higher VA rating. If you don't have 120V in then start checking backwards starting with power in/out of the door switch, then back to the unit disconnect switch, and back to the breaker if necessary. If you've got 24V out of the secondary go check to see you've got 24V at the thermostat between the R and C terminals, if you do the thermostat is bad. As with any electrical wiring make sure you've got good connections on all wiring terminations. Good luck, if you need an explanation of how to check the power in and out of the transformer let me know!
Apr 17, 2013 | Heating & Cooling
All I have is this Fasco # 71902773. Need the "D" number to know what to order
"D", when refering to an electric motor, is a dimension; it is the distance from the 'bottom' of the motor to the center of the shaft. I'm not sure why you would need it but if you do, sit the motor on a flat surface and then measure from that surface to the center of a shaft and you'll have the 'D'.
Your Fasco motor was made for Greenheck...google the model number and several sources come up such as this one: When searching use "Fasco 7190-2773" as the search phrase...
http://www.emotorpro.com/greenheck-115-volt-1100-rpm-oem-fan-motor-fasco-7190-2773---304970.aspx
John
Apr 01, 2011 | Fasco Centrifugal Blower 115v
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot...
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Oct 09, 2010 | Fasco Bradford White Hot Water Heater...
Need heat element for fasco wall mounted bathroom heater, the element is M shaped
try to found a local manufacture for heating elements, like http://rezistoterm.xhost.ro/ , give them the old heat element and the power of the bathroom heater (ex: 3000W and 220v, or 2000W and 110V) and they wil macke new oane and much chep like an original one.
Feb 14, 2010 | Fasco Heating & Cooling
I need a wiring diagram for Fasco model #659 serial # 447621 ceiling fan, heater, light unit.
Yellow wire is light. Blue is vent. Red is heat element and fan after going through a circuit breaker and thermostat. Brown is night light. White is common to ventilator housing. Black is power to switch cluster.
Jan 25, 2010 | Fasco Dryers
We have an imperial series whirlpool dryer approx 2 yrs old the dryer runs but does not heat up well
HI. There are a few areas i would advise to check to resolve this issue.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again. The most common cause of overheating will be a clogged ventilation assembly. Be sure to inspect the entire ventilation assembly for build up. This will cause issues, if obstructions exist.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Nov 20, 2009 | Whirlpool Dryers
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
Central vacuum cleaner problem
Fasco has been out of business for several years. The motors are still available. You will need to find the model number off your old unit. Once you have that model number you can find the replacement motor at one of these websites.
https://www.centralvacuumstores.com/motors/fasco.php
http://builtinvacuum.com/help/fasco/motor.html#motor
Jun 01, 2009 | Sebo K1 airbelt Bagged Canister Vacuum
Fahrenheat FFH1615 Heater Logo
243 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Thomas F. Schneider
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
