Question about Saeco VIA Venezia
Dear Expert, My Saeco VIA Venezia Problem is : Machine never comes up to Temperature (no Green Indicator Light), ie. doesn't heat and no pump. Like a fuse is blown. I have been told that there is a 'RESET' internally. Where can I find the reset - had a quick look but nothing obvious. Regards, Bob Greaves
  • 1,089 Answers
There is a fuse on top of the boiler. Its under a clip on the outside edge of the boiler. It is covered in a redish brown cover that you have tpo slide off to see the fuse. It is just better to replace the hole thing. If you don't have a pump also it could also be the switch. If you have any power its probably the fuse.
Posted on Nov 03, 2010
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
www.youtube.com/watch?v=8L8vdfMOx2g
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
Power light comes on. No heat and no pump
preview fuse located on the boiler,its looks like wire with diode,you can test with voltmeter,if fuse doesnt work make by-pass,connect two wires and taped with electrical tape,be carefull,good luck
Mar 02, 2010 | Saeco VIA Venezia
Saeco espresso machine Isn't pulling water at all
Can you brew a coffee? If not then the problem is the pump might be blocked.
Jun 22, 2009 | Saeco VIA Venezia
Water won't come through my Saeco via venezia coffee machine. It was working fine until I cleaned it so I don't think the pump has gone.
If the pump vibrates when trying to draw water then that is a good sign. Remo;ve the hose on the output side of the pump and turn it on to see if it draws water(BE Careful water and electricity love each other too much), it water flows out the output side, reconnect to boiler and test. If that did not solve the no draw problem then the machine is blocked either at the boiler.
May 11, 2009 | Saeco VIA Venezia
Saeco via venezia coffee machine wont prime
Turn machine on and make sure that the knob is fully opened, if the pump does not engage(vibrate) then either the machine is not getting power or there is a problem with the pump.
Apr 19, 2009 | Saeco VIA Venezia
Steam works, coffee doesn´t
Try to prime the machine.
Open the steam knob and press the buttom for coffee, when the water comes, close the steam knob.
Aug 24, 2008 | Saeco VIA Venezia
Left power and steamer on overnight and now machine doesn't work
they have a heat fuse attached to the side of the pump so when you do what you did that melts and does not damage the coffee maker
They charge $100 to replace which is a bit tough, you could bypass easily but could damage to machine it not careful
as we have two and one has just stopped pumping, not picking up water so maybe worn valves and I just have it all to bits and saw the heat fuse on the side of the pump,
Feb 22, 2008 | Saeco VIA Venezia
Overheat cutout switch
The coffe maker has a heat fuse attached to the side of the pump so when over heats that melts and does not damage the coffee maker
They charge $100 to replace which is a bit tough, you could bypass easily but could damage the machine if not careful
as we have two and one has just stopped pumping, not picking up water so maybe worn valves and I just have it all to bits and noted the heat fuse on the side of the pump
Feb 10, 2008 | Saeco VIA Venezia
Saeco VIA Venezia Logo
279 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
