Question about Sony KP-43T70 43" Rear Projection Television
Sony KP-43T75 green ghosting on lt side of image. auto convergence lines it up but 1-2 minutes later .... it's back. do the lenses hvae oil cooling? If so do they need cleaning and refilling with new oil? Perhaps new oil will solve the auto convergence problem( green ghost). Thanks in advance for any help that you send my way. May it return back to you ten fold!
  • 4,889 Answers
Oi? You mean thermal grease? No thats not the source of the problem in fact I think your problem is not related to the ICs itself. I suspect that you have bad capacitors in the convergence or deflection circuits that have to be replaced? If you are handy at working on electronics I suggest you take a look near the heatsinks(where the ICs are) for capacitors that are bulged or cracked at the tops. If you find any then they will have be replaced with those of exactly the same specs. That should do the trick.
Posted on Nov 03, 2010
IMAGE GHOSTING
Have you tried the auto converge or flash focus adjustment? This feature allows you to adjust the convergence automatically. If it doesn't work,convergence circuit is faulty. You need to replace the convergence kit, To do this you need some basics on electronics.
Feb 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My sony KP-51WS500 is having ghosting problems with kind of 3D image with the three colors showing seperate image lines. How do I fix this and what is the cost.
Shop cost u about $300.Ur convergence is dead,U know how to solders.?Buy a convergence kit to repair.Tries websites. Tv repair World.com,Tv repair Kits.
Dec 12, 2009 | Sony KP-51WS500 51" Rear Projection...
Double image, green and yellow ghosts, blurred image - Flash Focus does nto do anything, convergence adjustment does not work at all
That means convergence out ICs are not working, requires replacement.
If you want to replace convergence out ICs, let me know to provide you technical info.
Thanks.
Aug 17, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-43T75 color repair
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
I hope this helps you!
Fare well. :)
Iconoclast
Jun 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Red horizontal lines on the screen
do these appear around the images on the screen? look like a horizontal ghost around the image. if so you have lost horiz.convergence on the red. you might try a auto convergence setup in the menu on most rear proj. tv's if this dosent work then you need to try and find a shop.
Jun 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
SONY KP-43T75 HAS ISSUES
well sound like convergence for one and maybe another problem. First look at customer settings and look at convergence and try to realign. Then you can in Standby mode(Power Off) Press Display 5 Vol+ TV power on Remote. Fast. Now do you know what you want to get to? Because changing things here could cause serious problems with your set.
Sep 21, 2007 | Samsung TXM3281HF 32" TV
Distorted picture
dont touch those lenses that is not your problem the problem is your convergance ic are bad replace them and the fuses and this will fix your problem
Sep 15, 2007 | Sony KP-53HS30 53" Rear Projection...
Audio problem
Audio issue may be the cable. The green picture sounds like a convergence problem. Try to adjust the convergence in the menu and if that does not fix it you may need to get a repair facility out to take a look at the convergence amps.
Jun 06, 2007 | Sony KP-51WS520 51" Rear Projection...
Sony KP-43T70 43" Rear Projection Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
