Question about Brother DCP 130C All-In-One InkJet Printer
Unable to clean
Brother dcp 115c+ "Unable to clean refer to chapter troubleshooting and routine maintenance in user guide" how 2 reset the purge? in dcp-130c?
  • 1 more comment
  • mychard31 Jun 22, 2008
    turn off printer for 10-30 mins. then turn on back again. no development
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is there an error message to this or are you unable to print because it is purging the cartridges?
  • bspartsnmt
    bspartsnmt Jan 25, 2013
    Rror 46
Hello my name is teresa the problem is my printer just spits out the paper plain ihave a new cartage new ink wat to do
Posted on Jul 01, 2008
Unable to clean troubleshooting maintenance user guide
Posted on Jun 23, 2008
Unable to clean see troubleshooting and routine maintenance chapter in user's guide
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Its says. see trouble shouting and routine maintence.chapter. in users guide,.but theres nothing there in the book
Hi there. . . okay . . . Follow this step 1.) Unplug your printer. 2.) Plug your printer again while holding the menu button 15 sec. 3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK 4.) then numbers appear looks like this ###:### ###:###. 5.) now push the MONO button until the purge:#### appears on the LCD 6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok 7.) - switch off the printer ,switch it on - ready to print - CHEERS! email me if I helped you. . ryuuzaki182@gmail.com
Aug 29, 2009 | Brother DCP 130C All-In-One InkJet Printer
"Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET
b. 0 then press SET
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET
b. 7 then press SET
a. 8 then press SET
b. 3 then press SET
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET
b. 1 then press SET (To reset unit)
a. 9 then press SET
b. 9 then press SET (To exit Maintenance mode)
Jul 11, 2009 | Brother DCP 115C All-In-One InkJet Printer
Will not print
www.brother.com has those user guides by model number..
Jul 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
What 2 digit error code does the machine display, too?
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 130C All-In-One InkJet Printer Logo
1,499 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
